Broken Cluster Tab. Is it worth saving?
  • ///MLIFE
    • Feb 2012
    • 94
    So the SI Batteries died in my cluster. Having a friend help me remove it, the side tab on my cluster has snapped off. Does this mean my cluster is now toast and I should just get a new one?
  • ak-
    • 12422
    It can be held with one tab. It will still sit flush/straight.
    1991 325iS turbo
    • ///MLIFE
      • Feb 2012
      • 94
      Yeah but i'd rather not half ass it. Would it be worth attempting to glue it? Or securing so it sits correctly?
      • ak-
        • 12422
        It's so thin that I imagine it snapping again. It's hard to remove and install the cluster without bending the tabs a little to get it in/out.
        I don't see it as half assing really - it will still sit correctly and flush, but give it a go I guess. Maybe jb weld would be better?
        1991 325iS turbo
        • ELVA164
          • 4861
          Try this stuff:
          You should be able to get it or something like it at any auto parts store.
          • aegul44
            • Apr 2015
            • 396
            save it. Try gluing it or use plastic welding kit.
            Esquire E30 Build (87 325i Vert)
            Ultimate Tanning Machine
            • BMWManiac
              • Dec 2010
              • 1091
              I think someone should make some thin, aluminum tabs that look like stock and that can be fastened with just two screws into the housing....
              1997 Artic Silver M3
              CES GT4094r 651hp/615tq @ 24 psi
              • Staszek
                • 2533
                Yea this was what I was going to do when mine broke, I still would have but I ended up getting it restored and they put in a new housing.
                I used epoxy on a broken tab on my E46 HID headlight housings back in the day and the tabs stayed perfect even with all the stress of the temp changes, engine heat and movement of the car. If it can hold that it will hold a little tab on your cluster.
                • aegul44
                  • Apr 2015
                  • 396
                  Yeah. I had that issue before. I used gorilla glue and it work perfect for me. I see no reason to throw it away.
                  • Aleman
                    • Mar 2012
                    • 1604
                    The cluster is held in by 4 screws, so if one tab is missing or not secured, it'll still sit flush and level.
                    R135 /// 1990 Alpinweiß II 325is
                    └┼┼┘ /// 1993 Black/Black Convertible (sold)
                    ..24
                    • ChubbWubWub
                      • May 2015
                      • 26
                      One of mine broke too, I ended up super glueing it, then getting a cheap soldering iron from harbor freight, and melting the plastic as much as possible. Then got 2 part epoxy and covered the entire area just in case, held up perfect threw reinstalation of cluster.
                      Sent from my SM-N910T using Tapatalk
                      • Zesty Bonanza
                        • Apr 2011
                        • 88
                        duct tape; it even makes for a crack-free dash
