Hella dome light is junk (made in romania)
  • DesertBMW
    • Aug 2011
    • 1042
    New production made in Romania HELLA dome lights are total garbage. And they are not even cheap. The plastic switch arms brake within one year. It even broke from just sitting and it turned on the light and drained my battery.
    Too bad there are no other brands that you can buy.
  • 1843lamp
    • Sep 2015
    • 276
    Buy an original or two on eBay .
    • DesertBMW
      • Aug 2011
      • 1042
      They are all Hella made in Romania.
      • cory58
        • 1021
        Had the exact same problem. Battery started draining on my Touring and eventually realized is was the new Hella light. I like new parts, but this may be a case of used being better.
        1992 325i Cabrio
        1988 320i Touring
        2000 M5
        1977 530i
        2015 328i - Euro Delivery/Performance Center Delivery
        BMWCCA
        E30CCA
        • monty23psk
          • Mar 2008
          • 1289
          I have the same thing happen to me with a new Hella or BMW (made by hella) part. Only two options because old used ones will have the plastic be yellow. You can buy it from a reputable show and keep doing a warrant replace, I believe BMW dealer gives you 2 years. I have had it replaced like this before. Or, you keep / buy a used one, and pop out the black lever clip and add it to the new one. This is what I did last time. The material lasts long.
          Alex 88 m5 | 91 318is | 19 Subaru Ascent
          BMW Tool Rentals & Fender Roller
          • jdt10768
            • Feb 2013
            • 484
            I had the same thing happen just last month, black switch piece broke off - fail
            • cory58
              • 1021
              Bought most recent replacement from FCP Euro - lifetime warranty.
              1992 325i Cabrio
              1988 320i Touring
              2000 M5
              1977 530i
              BMWCCA
              E30CCA
              • ELVA164
                • 4861
                Saw this after I bought a pair and installed them... I'll see what happens, but they looked pretty similar to the original ones I took out. Luckily I rarely move the switches so hopefully it won't be an issue.
                • Originale30
                  • Sep 2017
                  • 165
                  Just bought a new pair myself :/ before seeing this post... they’re already being shipped here so I guess I’ll have to install and see how long they last me [emoji17]
                  • ELVA164
                    • 4861
                    If it helps, mine are totally fine. Granted I don't use the switches much, but I'm not concerned.
                    • Originale30
                      • Sep 2017
                      • 165
                      That’s good to hear! I installed mine about a week ago, I don’t use my switches to much either so hopefully they hold up.
