Dashboard gasket
  • kidneylover
    • Aug 2014
    • 51
    Dashboard gasket
    Doing a dashboard sawp soon and I read online they say to replace the dashboard gasket. Anyone know the part number to that gasket. Thanks
  • agent
    Vice Grand Pubaa
    • 7960
    The FAQ/DIY section is for staff-approved instructional posts only. Please do not ask questions there. If you don't know where to ask your question, post it in General Technical and we'll move it to the appropriate subforum if necessary. Thanks in advance.
    Originally posted by kronus
    • agent
      Vice Grand Pubaa
      • 7960
      Assuming you're talking about part #4, the part number is 64 11 1 370 937.
      http://www.realoem.com/bmw/enUS/show...diagId=64_0447
      • kidneylover
        • Aug 2014
        • 51
        I apologize and thanks
        • agent
          Vice Grand Pubaa
          • 7960
          No problem - all posts there are moderated and won't show up until they are manually approved, so you'll typically get an answer much faster in one of the technical forums.
          • digger
            • Nov 2005
            • 6092
            what should one replace when doing a dash swap?
            • jeffnhiscars
              • Jun 2011
              • 6010
              The hvac gasket as above although you can use strip weatherstripping as well. You may also want to replace the foam gaskets on all the flaps as they are guaranteed to have dried out and shredded off.
              Alice the Time Capsule
              • 88BlackS-ETA
                • Mar 2013
                • 322
                When I did my dash swap, with a new dash from BMW, I replaced that gasket with weatherstripping from HomeDepot. I also unwrapped all harnesses and rewrapped them and took out stereo wiring because I ran new wires to all my speakers back in 2010. When they were unwrapped I checked for cracks in any insulation before rewrapping.
                Feedback Thread
                • digger
                  • Nov 2005
                  • 6092
                  Are there specific part numbers ?
                  • jeffnhiscars
                    • Jun 2011
                    • 6010
                    Not for the flaps. I just used a roll of 3/8" weather stripping.
