318 is Check panel secret...
  • scott_is
    • Aug 2007
    • 310
    Well today I was working on my car with a friend. I asked him to take apart the interior while I removed stuff under the hood. Long story short he removed the check panel cover and he found something I didn't existed.
    There is a small circuit board behind stamp HELLA. So my question is what is it for?
    I can get pictures if needed.
  • E30Idea
    • Mar 2007
    • 2196
    First
    It makes your car fly
    ** Lot's of M20 turbo parts for sale.**
    Turn key track car.
    http://www.r3vlimited.com/board/showthread.php?t=222066
    • Erik
      • Oct 2005
      • 5370
      Originally posted by E30Idea
      First
      Yes you just have to short the third and sixth pin and you're off!!!
      Seriously I have no idea what it's for though. It's a pretty smart little box though.
      -Erik
      Originally posted by 87e30
      • NOMAD
        • Feb 2007
        • 1502
        Take a pic.
        Sounds like it's the circuit board for the 318 check panel. You do know that it is not a cover right? The SRS and seat belt lights are in the flat black panel and are supposed to light up. Maybe yours isn't working so you thought it was just a flat plastic cover?
        '74 2002 - Build blog at
        nomads2002.blogspot.com
        • gearheadE30
          • Jun 2007
          • 3734
          The interesting thing is that there are other lights back there. There is one that says "overheat," "airbag," "SRS," and the seatbelt light. Not quite sure how to get them to work though. Shine a light through the back of the panel and you will see what I'm talking about.
          Project M42 Turbo
          • NOMAD
            • Feb 2007
            • 1502
            There should be a wiring harness that plugs into the back of the check panel.
            The Seatbelt and SRS lights should come on when you start up and shut off in about 8 seconds.
            Not sure you want to test the overheat light. Disconnect a coolant hose and go for a drive on the highway... see if the light comes on eventually. ;)
            • moatilliatta
              • 6158
              is their a part# on it?
              @Zakspeed_US
              • gearheadE30
                • Jun 2007
                • 3734
                Yeah, I know. I actally ditched the panel for a custom dome light (off of a silverado, it actually looks pretty good). I was just tying to figure out why they were there considering that the panel doesn't come with bulbs for those positions.
                Project M42 Turbo
                • SamE30e
                  • Sep 2007
                  • 4319
                  It's the cpu for the flux capacitor.
                  1985 325e 2.8 Turbo VEMS
                  • scott_is
                    • Aug 2007
                    • 310
                    Take a pic.
                    Funny totally forgot that I posted that question.
                    Here is picture of what I'm talking about. My question is do I need to keep this thing or is it only used by the airbag( I'll be swaping the aribag wheel for a MtII) I know nothing about electronic....
                    • DCColegrove
                      • 2748
                      "Over heat" is for the Catalyst (required someplace but I can't remember where).
                      SRS / Airbag was waffleswaffleswaffles US or UK.
