I just installed an mtech2 wheel in my car (previously airbagged) and I actually ran into a different problem, but I think you can use my fix. When I put the mtech 2 on it was shorter than my stock wheel, and it didint fit quite right it slid back and forth. So, I bought some locking washers, and used them as spacers between the wheel and the nut.
Im thinking if you just put the washers on before putting the wheel on, then put the wheel over, it will push it out (as far as u need depending on how many washers u use). Then tighten the nut over it, and voila. Not sure how far you'll need it out because the bolt only extends so much, but at least its worth a try before anything else more drastic.
i'm already using a couple of washers to fix the problem you're talking about. but thanks :)
