I don't fit quite right with my mtech ii wheel.
  • mikeedler
    • 6707
    they dont make spacers for stock wheels! the steering wheel you see in the pic has 6 allen heads that hold ot to the spacer, cant do that with a stock one! the problem you are probably experiencing is that you have the WRONG STEERING WHEEL!!! It is probably a E34 wheel, they are larger, but look the same.
    • Kruzen
      • Mar 2004
      • 5603
      i bought it from a user on this forum who claimed it was an e30 mtechii wheel.. he goes through alot of stuff ( sold a wheel to dn as well).. so i think its the right one? is there any way to really tell?
      Who doesn't love a little BBQ?
      Griot's Garage at a Deep Discount
      • Digitalwave
        is a poseur
        • 6293
        Under the center roundel there should be a stamp that says E34 or E30.
        RISING EDGE
        • Kruzen
          • Mar 2004
          • 5603
          under the roundel? or under that little pop-off cover.
          removing the roundel will just cost me more money :( heh.
          • Digitalwave
            is a poseur
            • 6293
            Under the pop off cover where you put the bolt on the wheel...
            RISING EDGE
            • Kruzen
              • Mar 2004
              • 5603
              just took it off, no such stamp..
              There is a date though! heh. Juni 1992
              not that that helps anything. i looked all over, nothing resembling E** at all.
              • Kruzen
                • Mar 2004
                • 5603
                Here's some pictures..
                first: the backplate
                Closeup of the hub itself:
                Me sitting straight legged, notice the lack of space between my right knee, and the steering wheel
                Me sitting with my knee resting against the center console, notice how i can now fit my fist through the gap for a turn:
                • hamann318is
                  • 3382
                  On the M-tech 1 one, it's under the roundel. But I'm not even sure if yours can pop off the roundel.
                  The BMW 318 is back. With a vengeance.
                  • mikeedler
                    • 6707
                    it sure looks like a E34 wheel 2 me. look at some pics on the net, the E34 wheel has longer spokes from the center to the wheel. hard to tell from pics though, but the only way to tell without having another wheel.
                    • chesster6969
                      • 321
                      That wheel looks to skinny compared to my Mtech 2.
                      Dont have my digi cam with me but the spokes look skinnier since they are longer.
                      Im 6'3" and my legs dont bump like you state, and I have regular vinyl seats right now, not sports.
                      • Kruzen
                        • Mar 2004
                        • 5603
                        damn.
                        maybe you could take some pics and measurements of yours?
                        • SebSter
                          • May 2004
                          • 192
                          I just installed an mtech2 wheel in my car (previously airbagged) and I actually ran into a different problem, but I think you can use my fix. When I put the mtech 2 on it was shorter than my stock wheel, and it didint fit quite right it slid back and forth. So, I bought some locking washers, and used them as spacers between the wheel and the nut.
                          Im thinking if you just put the washers on before putting the wheel on, then put the wheel over, it will push it out (as far as u need depending on how many washers u use). Then tighten the nut over it, and voila. Not sure how far you'll need it out because the bolt only extends so much, but at least its worth a try before anything else more drastic.
                          1990 325ix
                          • Mystikal
                            Wheel Fitment Expert
                            • 9602
                            That is an E34 wheel. Look at the bottom spoke and compare it to mine:
                            Slightly logner on yours, and very slightly differently shaped. I noticed it immediately when I saw your pics.
                            • Kruzen
                              • Mar 2004
                              • 5603
                              son of a bitch! mine is bigger!
                              how the hell did this happen :(
                              i guess i'll have to buy another one on ebay.. and then toss this one up..
                              • DanGillan
                                • Mar 2004
                                • 4061
                                that sucks man, he sold me the correct one (same guy) i hm... wierd, sorry to hear that man, good luck with the quest for another one...
                                Dan
