e36 window switches in e30
  • DSchultz325e
    • Aug 2004
    • 1158
    omfg it is spelled voila, ugh
    I retired my E30 for now...
    E46 323i
    David Schultz
    • spencers
      • Jan 2004
      • 1150
      dont coerrct me speeling!
      Anyways, my switches are in the mail.
      I opted for the ones on the left.
      • bimmerphile
        • 3495
        well then it sucks to be you...those wont work.
        you need the right-hand switches.
        • Kruzen
          • Mar 2004
          • 5603
          so you have to have white-bottom, prong style switches?
          Who doesn't love a little BBQ?
          Griot's Garage at a Deep Discount
          • spencers
            • Jan 2004
            • 1150
            you gotta be shittin me kris. why not the ones on the left?
            • hella 325
              • Sep 2004
              • 380
              so how do you do the one touch switch retrofit?
              Russell
              1987 325is
              1992 240sx coupe
              1994 525i
              • UNHCLL
                • 8790
                One more thing I've never understood. Why, in that article, do you need e30 donor switches?
                I figured all you have to do is get the e36 switches with the wire,
                chop the e30 switch off the wiring harness,
                and expose the wire left on the e30 side,
                expose the wire on the e36 side,
                solder them together,
                and whalla?
                Why would you need the e30 switches? Still can't understand that.
                so incase you fuck it up, you can go back to stock.
                something you know that works
                Below the radar...
                • spencers
                  • Jan 2004
                  • 1150
                  and whalla?
                  Ah, I see, very true. I would also be able to solder the wires back on if I went back to stock as well.. It's just as easy, however not as permanent / genuine.
                  • spencers
                    • Jan 2004
                    • 1150
                    WRONG!!!
                    These switches are FAR greater than those ugly e30 switches! I chopped off the old e30 switches and soldered on the e36 switches. Went along just fine!
                    Just be sure to not get the wires mixed up when you wire them up. Fuses blow!! :P
                    • Kruzen
                      • Mar 2004
                      • 5603
                      WRONG!!!
                      Write up, write up, write up, write up
                      *chants* just curious wehre'd you get em.
                      • DSchultz325e
                        • Aug 2004
                        • 1158
                        uhh...those are upside down.
                        E46 323i
                        David Schultz
                        • spencers
                          • Jan 2004
                          • 1150
                          WRONG!!!
                          *chants*
                          what the fuck. my writeup is right there.
                          • Kruzen
                            • Mar 2004
                            • 5603
                            WRONG!!!
                            *chants*
                            so the non-prong style connectors worked?
                            • spencers
                              • Jan 2004
                              • 1150
                              Yes Sir Kruzen.
                              Yeah they're upside down. I don't give a flip! They work.
                              But the odd thing is.. They white arrow actually makes it go down, and the outlined arrow makes it go up. I may have wired it wrong or something. But honestly I don't care too much since they work just fine! I'm proud of the work.
                              • Kruzen
                                • Mar 2004
                                • 5603
                                Yes Sir Kruzen.
                                wehre'd you score the switches and harnesses from, just curious?
