Help with H1 Ellipsoid Install - wiring - thanks.
  • royalflush313
    • Mar 2004
    • 2070
    Well I received some euro smileys in the mail couple days ago, so today I decided to put them in.
    I removed the grille, sealed beams, re-routed the sidemarker light wiring over to the headlight area (note that I have euro trim, so I dont need to splice in to make two ends).
    Well then i got stuck with the wiring part.
    I searched, and found http://www.archercc.net/tech/lighting.htm but still lost because i don't have the connectors that are pictured on the site :?
    First, I seem to have 3 extra blue plugs, and 2 black plugs that i dont know where it connects to.
    Should I just rip off each plugs and wire it in from the existing wiring in the car?
    TIA.
    - Hiro
    ~ Go Canucks Go! ~
  • Spaz
    Crazy Canuck
    • 2276
    give me a call tomorrow, i'll see what i can do...i'll be home all day. its kinda confusing with all the wiring laid out...
    Cam .W '91 325is
    Spaz's 1991 Alpine White???? S52 Build Thread...
    • spencers
      • Jan 2004
      • 1150
      Re: Help with H1 Ellipsoid Install - wiring - thanks.
      That's what I would do.
      • royalflush313
        • Mar 2004
        • 2070
        UPDATE:
        I finished installing the light.
        It took me good 3 hours to do. :(
        Well I didn't know that you don't need any wiring to get the smileys work, and that basically it's plug-n-play once you change the plugs.
        I was confused because there were so much wirings included, and I assumed that I'd need to use them.
        David (euro3) thanks for the lights. Everything seem good. 1 H1 bulb was dead (i thought i wired the lights wrong, and i was about to pull my hairs out haha).
        Follow-up-question:
        Anyone have the part # for the adjusters, and the black plastic socket that the adjuster goes in to?
        Or anyone have some lying around? Thanks :)
        ~ Go Canucks Go! ~
        • Spaz
          Crazy Canuck
          • 2276
          UPDATE:
          Follow-up-question:
          i should have some when i get my car back i'll let u know.
          Cam .W '91 325is
          • spencers
            • Jan 2004
            • 1150
            Yeah I need to change mine as well :x
            Pics yet?
            • royalflush313
              • Mar 2004
              • 2070
              nah havent taken any pics yet. I will sometimes soon.
              So meanwhile, anyone have part #s?
              ~ Go Canucks Go! ~
              • BMWM5LOVER
                • May 2004
                • 261
                how can i get all 4 lights (i have euro ellipsoids), to work when i turn on my high beams, as opposed to just the high beams
                1991 BMW ///M5 .:Black on Black:. - Modded
                1988 BMW 325i .:Zinnebarrot on Black:. - Modded
                1999 Volvo V70R AWD .:TI Silver on Black:. - Modding has begun
                1999 Subaru Legacy AWD/5 .:Green on Grey:. - Modded Rally Style
                1990 M20iS Alpwhite II- Sold
                • PanamaE30
                  • Oct 2004
                  • 768
                  I think you just splice a jumper on the relay..
                  least that's what i've read. I may be confused.
                  1988 325iC - "Betty" - Daily Driver/Project Car.
                  1993 318i - "The Golden Dream" - Dad's Car.
                  1995 318ti - "Hellrot" - R.I.P.
                  • brodee
                    • Jan 2004
                    • 2914
                    They should all 4 come on when you turn on the brights. Isn't it that way from the factory??
                    "Modern cars may be able to outgun it, but few can match its character, its motorsport spirit, and the way it plasters a huge grin on your face at any speed." - Patrick George
                    1988 M3 - Track Rat
                    1989 325iC M50 Vert
                    1989 325i Coupe
                    1991 318is
                    1995 318ti Club Sport
                    2006 330i e90
                    2008 Tundra Crewmax
                    • royalflush313
                      • Mar 2004
                      • 2070
                      no it wont.
                      Becuase when you install the ellips, you lose the highbeam wiring that goes into the low beams. You gotta do somethign with the relays. I haven't done that yet. I have other issues first
                      Anyways, how bout someone answering my questions?? haha thanks :D
                      ~ Go Canucks Go! ~
                        • 34839
                        no, because sealed beams have dual fillament low beams, ellipsoids do not, thus the different wiring. it's as easy as stuffing a wire under the relays to connect the right pins though.
                        • brodee
                          • Jan 2004
                          • 2914
                          ahhh.. sorry. I just put the euro elipses in my car (which had US elipses) and didnt' have to do that.
                          1988 M3 - Track Rat
                          1989 325iC M50 Vert
                          1989 325i Coupe
                          1991 318is
                          2006 330i e90
                          2008 Tundra Crewmax
                          • spencers
                            • Jan 2004
                            • 1150
                            Near the bottom
                            • mgold
                              • 709
                              I didn't like the idea of jumping the relays together, so here's an impromptu schematic of how I converted from US sealed beams to US ellipsoids. Either method should work.
