yellowing out fog lights
  • jaye30
    • 561
    i have the late model fogs. i want to yellow them out. whats the best product to buy. ive read yellow-lamin? or duplicolor? also how do i remove the lenses of the fogs.
  • e34john
    • Apr 2006
    • 3599
    lamin-x
    put the fogs in the oven to remove the lens
    • td325ic
      • Feb 2006
      • 786
      Unlike headlights, you can't bake the foglights to remove the lenses. At least not in my experience. I know Jordan (Stück) ran into the same problem.
      If you want to remove the lenses I think your only option is to break the glass.
      If someone has a successfully removed foglight lenses intact then I'd like to hear about it.
      BTW, if you do decide to put them in the oven then make sure you remove the cap on the bottom, otherwise you will almost will surely crack the lenses.
      • moatilliatta
        • 6138
        i believe a heat gun works better than an oven. You can put the heat where you need it.
        @Zakspeed_US
        • iX-treame
          • 440
          I used a torch but yea along those lines....
          '88 325iX -Totaled
          '97 M3 - Sold
          '85 euro e30 Pete McHenry 2.8L m20 Stroker - Parting out
          '89 325is - Sold
          '95 540i 6spd
          '87 325is M Technic I s50
          • EA8
            • 328
            keep us posted on how it turns out ... I've been meaning to do the same to my ix fogs. pictures would be great. GL
            Cheers
            • jaye30
              • 561
              will do. thanks for the insight
              • e34john
                • Apr 2006
                • 3599
                I did break my glass too, but I couldn't get all the small pieces off right around the edge. Using a dremel didn't seem too safe so I heated it up some and used a screwdriver to scrape it out. Heatgun would work too I guess.
                • maco325e
                  • May 2007
                  • 177
                  Boiling water worked for me.
