LED's all around
  • mattdk318i
    • Jun 2006
    • 3953
    #31
    I def like the trunk light. I have the dual "mod" but its a bit like candle behind plastic
    link?
    • everlast
      • Oct 2004
      • 225
      #32
      link?
      He stated the part numbers:
      Originally posted by Wiglaf
      Product: 3610-x4 LED Festoon bulb $ 1.89 (each)
      Options: Cool White 3610-CW4 0.95
      Result: Got this for trunk lights and plate lights. They are bright enough, crisp cold white in color. I would recommend getting slightly larger though, these are 36mm long. I had to bend the clips a little bit, 39mm might have been a better choice. The 4-led is plenty for the plate but the trunk it wouldn't hurt to amp it up some.
      Edit: here's the link, 2nd group down. He suggested 39mm would be better, so 3910-CW6.
      Super Bright LEDs is one of the largest online retailers of LED lighting for commercial and residential uses. Enjoy free/same-day shipping on qualifying orders!
      • Wiglaf
        • Jan 2007
        • 1513
        #33
        Originally posted by everlast
        I know I'm late to ask this, but how about side by side shots of each? IE, the left taillight fully LED and the right fully incandescent? Otherwise its really hard to judge since the camera adjusts for the differing light levels. :(
        I'll try to when I do the update, gotta go in there again when the 5W's come in anyways.
        Originally posted by u3b3rg33k
        If you ever sell that car, tell me first. I want to be the first to not be able to afford it.
        • everlast
          • Oct 2004
          • 225
          #34
          Awesomeness.
          • Wiglaf
            • Jan 2007
            • 1513
            #35
            What I'm getting to replace the wrong stuff. fingers are crossed.. decided to wait on the extras for the other car too. except the dash, not sure if I will decide on blue or white yet.
            4 168/194 Miniature Wedge Base Socket $ 1.19
            Twist-Lock T10S-TW
            2 WLED-xHP5 Wedge Base Bulb $ 5.95
            White WLED-WHP5
            Blue WLED-BHP5
            1 LED bulb Flasher Unit $ 12.95
            CF13GL-02
            2 BA15 24-LED bulb $ 7.49 (attempt #2 for front turns)
            Wide Amber 1157-A24
            2 WLED-x5 LED Wide Angle LED bulb $ 2.99
            Red WLED-R5
            Amber WLED-A5
            • Wiglaf
              • Jan 2007
              • 1513
              #36
              update
              5W tails not in but I did get other stuff
              Twist-Lock T10S-TW
              result: not needed, dash came with them. duh.
              will need if yours were missing to begin with.
              White WLED-WHP5
              Blue WLED-BHP5
              Result: did not use the white yet but did put the blue into my GF's iX.
              It looks about the same as the pic in real life.. I ALMOST got the effect I wanted, but it seems that the orange is quite persistent. I think that either those colored light tubes can actually fight the blue, or that some of the smaller bulbs were assisting and I would need to blue those as well. I did pull the orange caps off the bulbs. I'm considering taping over the light tubes that bring the light around to the front.. this is where the bulk of the orange seems to be coming from. but then i could lose the needles.. guess if I was hell bent on this I would yank the light pipe and add some led's for the needles down there.Brightness is not an issue.. they seem stock or better. getting the uber tower bulbs probly would have been a waste.
              Either way I'm looking foreward to putting the white in my car and avoiding this coloring issue.
              CF13GL-02
              result: performs as advertised. I got the right one! regular speed blinks.
              in case you never had the pleasure of locating it before.
              Wide Amber 1157-A24
              result: not quite as bright as stock but does fill the lens suitably. The picture is not a good comparison but I feel that this is bright enough. when the other tower style bulb (that I used in rear blinkers) is available in dual brightness amber I would prefer that, they are brighter than stock. This is fine for now though.
              these rear pics are same setup as before, brake light is not on this is just the rear marker.
              looks crazy bright but this is just the camera not dealing with darkness well. I'm pretty happy with the result, it is not blinding but much better than stock.
              Red WLED-R5
              Amber WLED-A5
              Result: side markers.. swapped in just fine and are about stock brightness, maybe brighter. better color for sure.
              • everlast
                • Oct 2004
                • 225
                #37
                Alright, great update dude.
                Once you get it all sorted are you going to compile all this? Even with my OCD I'm getting lost with the details. :D
                Another question.. Does the new blinker unit "tick"? The one on my bike didn't and it was actually a PITA.
                • Wiglaf
                  • Jan 2007
                  • 1513
                  #38
                  yeah, I'd like to re-arrange the 1st post or just re-post as something we could sticky or something.. getting these part numbers right and trying out for which ones look ok is a PITA and would prefer to save other people the trouble..
                  the blinkers do still have the relay click noise.
                  • bostonbmw
                    • Nov 2004
                    • 429
                    #39
                    Originally posted by bimmerpirate
                    no, no, no.... like this
                    Daft Punk E30 haha
                    • Wiglaf
                      • Jan 2007
                      • 1513
                      #40
                      UPDATE
                      got the 5W's in.
                      and by request.. a set of pics with stock light bulbs on the left, and LED's on the right.
                      The camera doesn't show the brightness and color contrast as well as seeing it in person, but the bulbs are not as bright and more yellowish. The LED's put out much better color.. the markers are about same brightness but the turns and brakes are much brighter.
                      was hard to get both blinkers in the same pic, it's almost like they were alternating the LED was so much snappier.
                      about those brakes..
                      LAAAASERS
                      the 5W bulbs are very bright.. 3W would have been sufficient for sure.
                      • ///M42 sport
                        • 3952
                        #41
                        UPDATE
                        Nice, thanks for the comparision...so you definately think the LEDS are brighter and show crisper colors? Thats really cool, I'll try the 5w then if they are truly that much brighter.
                        The website was kinda confusing on which led matched up where. Can you provide the part #'s for the LEDs you used? Thanks.
                        • Fidhle007
                          I can fly, motherfucker
                          • Oct 2005
                          • 7209
                          #42
                          Blue WLED-BHP5
                          Ghey. ;)
                          Besides, it's been done...
                          I love mine but here's a tip, if you rotate the bulbs a bit you can maximize the blue. They're still pretty directional and the orange light bars have a strong effect but you can tweak it pretty well if you're diligent. They way I have mine the fuel and coolant gauges are pretty orange and everything else is very blue, except my tack fades slightly towards the redline which couldn't have worked better if I'd planned it. :D
                          '89 325is S50 Track Montser
                          '04 X5 Daily/Tow Vehicle
                          http://www.avarestoration.com
                          http://www.myspace.com/brendanfiddle
                          Click here if you want to be my zombie slave...
                          http://www.youtube.com/user/Fidhle007
                          • Schnitzer318is
                            • Jan 2008
                            • 2057
                            #43
                            Looks pretty good, though we need daytime shots for brightness comparisons. LEDs look super bright at night.
                            My attempt came out decent. I should have done the inner boards like I did the signal lights... using 3mm LEDs. But man did that suck for soldering. There are 96 3mm LEDs in each turn signal alone, and the fronts have 60 3mm LEDs on each side. For the inners I used 10mm bulbs which require less bulbs to achieve the same brightness, but you get those patterns instead of the appearance of one light that you get with the smaller 3mm. Anyway:
                            Daytime LED Video
                            Nighttime LED Video
                            "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
                            91 318is Turbo Sold
                            87 325 Daily driver Sold
                            06 4.8is X5
                            06 Mtec X3
                            05 4.4i X5 Sold
                            92 325ic Sold & Re-purchased
                            90 325i Sold
                            97 328is Sold
                            01 323ci Sold
                            92 325i Sold
                            83 528e Totaled
                            98 328i Sold
                            93 325i Sold
                            • ///M42 sport
                              • 3952
                              #44
                              anyone else trying the leds in the brake lights?
                              • whysimon
                                • Jan 2007
                                • 661
                                #45
                                I like the cluster
