LED's all around
  • Wiglaf
    • Jan 2007
    • 1513
    LED's all around
    I just ordered up $200 of LED action from superbrightleds.com.
    Stay tuned, hopefully this won't suck.
    Quantity: 4
    Product: T1.5-xHP Instrument LED bulb $ 2.79 (each)
    Options: Blue T1.5-BHP
    Quantity: 4
    Product: BA9s-x-x-12V Wide Angle Bulb $ 0.98 (each)
    Options: 120 Degree Red BA9s-R-x-12V
    Quantity: 4
    Options: 120 Degree Amber BA9s-A-x-12V
    Quantity: 1
    Product: Spotlight Rechargeable LED Light $ 19.95 (each)
    Options: Black
    Quantity: 2
    Product: BA15 3Watt LED bulb $ 12.95 (each)
    Options: Amber 1157-ALX3
    Quantity: 2
    Product: BA15 18 High Power LED Tower bulb $ 17.95 (each)
    Options: Amber 1156-A18-T
    Quantity: 2
    Product: BA15 24-LED bulb $ 7.49 (each)
    Options: Wide Red 1156-R24
    Quantity: 2
    Product: BA15 5Watt LED bulb $ 22.95 (each)
    Options: Red 1156-RLX5
    Quantity: 6
    Product: 3610-x4 LED Festoon bulb $ 1.89 (each)
    Options: Cool White 3610-CW4 0.95
    Quantity: 2
    Product: BA15 19-LED bulb $ 6.99 (each)
    Options: Wide White 1156-W19 3.00
    SUBTOTAL: 198.65
    SHIPPING: 10.00 UPS Ground (Estimated)
    TOTAL: 208.65
    Originally posted by u3b3rg33k
    If you ever sell that car, tell me first. I want to be the first to not be able to afford it.
  • e30slut
    • May 2008
    • 793
    subscribed
    • CorvallisBMW
      Long Schlong Longhammer
      • 13039
      go on...
      • asubimmer
        • 6482
        LED's have come a long way. The new stuff can be REALLY bright. I'm still thinking about LED lighting on my car or bike...
        • slow e30
          • Jul 2009
          • 398
          on a car is questionable with the style/year. but on a bike it shouldnt be a consideration, it SHOULD be done. safety is first, and them bright annoying lights helps alot.
          • dude8383
            • Jan 2005
            • 10387
            go on...
            werd. i'd like to know where all of those go.
            • bimmerpirate
              • Feb 2007
              • 561
              i know a few of those are going to suck. LEDs make nice spot lights which means they suck at illuminating an entire reflector housing that just about all the light housings on our e30's are. you're going to have bright centers for all your lights and the rest is going to be quite a bit dimmer.
              also, you forgot to get the turn signal relay for use with LED lights. without it, your turn signals are going to flash like one is blown out because there is not enough load for the relay to work properly.
              • Wiglaf
                • Jan 2007
                • 1513
                estimated delivery: 18th
                It's a bit of a variety pack there, some have higher viewing angles than others. I'm hoping to get some good comparisons. I also am thinging I should have gotten the dash lights in wite in case I don't like the blue, but will wait to make sure they are the right ones.
                the turns and fronts I went for high viewing angle, the rears I got some lame ones for the always-on and the mega-bright for the brakes.
                I didn't think our blinkers did the double-speed thing, I was planning on modding the check panel to deal with the lighter load.
                  • 34827
                  it's already been done. It worked out fine, they werent "spotlights" at all. but he used quite a bit of LEDs to make it work.
                  • bimmerpirate
                    • Feb 2007
                    • 561
                    hm, the last time i saw someone try the LED bulb replacements in the tail lights and brake lights, they wound up as spots. it'd look much better as a whole circuit board of LEDs though.
                    and yeah, our e30s do the double flash when the turns are out. also, it's not the check panel you have to modify. it's all the sensors that detect a light out. i know all the sensors for the rear lights are that little black box in the trunk by the antenna. I've already figured out the license plate lights and how to disable that much of it.
                    • slow e30
                      • Jul 2009
                      • 398
                      the guy who did it correctly pulled it off. just looked weird in such a old car. whatever floats his boat.
                        • 34827
                        they weren't LED bulb replacements, those are just stupid.
                        he remade the entire reflector housing using LEDs
                        • newman
                          • Mar 2007
                          • 1159
                          What about these joints:
                          1987 325is: 495whp/400ft-lb
                          UPDATED 03/12/10!: RB26DETT Swapped E30
                          • bimmerpirate
                            • Feb 2007
                            • 561
                            +1
                            and what the OP got were bulb replacements. thus what I was saying before. I know about the guy who rebuilt his lights with LEDs. heck, I'm already working on doing that with mine. just trying to figure out the best way to split the tail light housings without breaking anything then I can start putting things together. I have the fronts halfway done. just need to start soldering things up there and install it.
                            • e30slut
                              • May 2008
                              • 793
                              i see nothing
