New Red Tails
  • Avus E30
    • 3650
    New Red Tails
    They arent anythnig special but done right they look right.
    Just thought someone may wanna see them.
    HDE30 <3
  • Jordan
    • 12916
    Webshots does not allow remote linking. Please host your picture files elsewhere if you want people to look at them.
    https://mtechniqueabs.com/
    • Jand3rson
      • 37587
      That looks great. I need to do mine to hold me over until I get smoked ones.
      • e30 gangsta
        • 3877
        which paint did you use?
        • Avus E30
          • 3650
          Testor's Candy apple red
          HDE30 <3
          • PeaveyBassist
            • Sep 2004
            • 3511
            That looks really good. Looks like an exact match. Did you paint the whole tail? Or just the turn signal portion?
            Will
            RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
            Welcome e30 (brilliantrot '90 325is) 12/23/06
            DaveCN = Old Man
            My signature picture was taken by ME! Not by anyone else!
            If people keep quoting me in their sig, I'm going to burn this motherfucker down.
            • Avus E30
              • 3650
              I sanded the whole tail with 600 grit paper and then cleaned and rinsed. Taped off the reverse ane thn did two coats Candy Apple red then did two clear coats after i removed tape over reverse lights. I thought it turned out well
              HDE30 <3
              • gstuning
                • 833
                It sure does,
                I´ll be doing that very soon as well
                Gunni
                @ Prodrive / Aston Martin Racing
                • e30 gangsta
                  • 3877
                  clearcoat is basically clear enamel? And 1 can was enough?
                  • e30 gangsta
                    • 3877
                    • Avus E30
                      • 3650
                      it was a clear coat spray from testors if i can find the can ill give ya the number for it i did two coats of red and two clear coats
                      HDE30 <3
                      • Jand3rson
                        • 37587
                        I just went out and bought the same, I'm going to do mine when we get a warmer day.
                        • Avus E30
                          • 3650
                          good luck lets see some pictures when you are finished
                          HDE30 <3
                          • Digitalwave
                            is a poseur
                            • 6299
                            It looks good now, but I could never paint my whole tail light. That paint isn't meant to last in the elements and instead of just having your turn signal look dull, now the whole tail light will eventually.
                            RISING EDGE
                            • Jand3rson
                              • 37587
                              It's the kind of thing that can be easily re-done though TJ, so it's not a big deal.
                              Besides, I plan to get MHW smoked tails at one point, so the all-reds should suit me just fine for a while.
