Adjustable Euro Smileys
  • Kristuphir
    • 402
    Just picked up a set of nearly perfect Hella Euro smileys for $168 shipped from Germany - think i did ok. They have the vacuum level adjustment - any clues as to how I'd make this work on my US-spec E30? Or would it be more complicated than it's worth?
    I did a quick search and found nuthin'.
    Chris
    The Hunt: Part IV is over.
    • 37828
    As said, probably gonna take more effort than its worth for the adjusting thing
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • Bavarian3
      • 1230
      As Mr325 said, it will take a lot more than using a simple system to adjust the lights from the inside of the car. Although if you can find a wreck european E30 that used the adjustable lights, it might be worth it...
      It's pretty neat though they BMW offered this in the late 80's/early 90's....
      • Kristuphir
        • 402
        so if, by chance, i wanted to try it anyway - whether or not I used all-stock parts - does anyone know how?
        Chris
        • Addissimo
          • Mar 2004
          • 1820
          I was looking into using those headlights a while back before i went the bi-xenon route... If you look at the ETK under a later model european car, it shows all of the partnumbers... ahhh fuck it- here you go.
          -Addis
          http://www.realoem.com/bmw/showparts...g=63&fg=05
          Doing something M50 related? -> http://www.addissimo.com
          On Myspace? ->http://groups.myspace.com/r3vlimited
          BF2142 SN = BillyGoose
          • Kristuphir
            • 402
            thank you, that looks like a good start.
            Chris
            • Axxe
              • Aug 2004
              • 3355
              See if Patrick @ BMA can get those parts for you. It would be a lot cheaper going through him than the dealer if you decide to buy new. Looks like it can be done for under $200, which would be a pretty neat feature to have.
              Keep it slideways!!
              • Ryan Stewart
                I Love Miatas
                • 8978
                Most people disable the vaccum system. See if you can do the electrics from the E34, its less likely to fail.
                Im now E30less.
                • E30325i
                  • Oct 2004
                  • 25
                  it works off of mineral oil...if you want i have a controller for them that fits in the knee bolster, but no lines...i'm sure you could prolly use the plastic piping for fish tank airator things.
                  • Kristuphir
                    • 402
                    All good suggestions, thanks. Would the electrics from the E34 be fairly easy to retrofit?
                    Ooooh. PM me with how much you want for that. Either way, i think this would rock if it worked...
                    Chris
                    • BavarianBimmer
                      • 951
                      That system is sooooo fucking unreliable as an Italian car :x
                      1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
                      1997 E36 328iT
                      1990 E30 325iT 24v SOLD
                      1989 E30 325i 2.7i M-Technic II SOLD
                      • bimmerphile
                        • 3495
                        -Addis
                        If that is what you want to do, then upgrade to the E34 style electric units. The Vacuum/hydraulic units are far too prone to leaks.
                        • demlotcrew
                          • May 2004
                          • 297
                          E34 motors are about 100 times easier to install than the hydraulic unit, and it costs less too!
                          I have done it, i also fitted self leveling sensors because of my Xenons, and they work with the E34 motors.
                          Andrew
                          Andrew AT E30zone.co.uk | H23-is | S14
                          • cramer
                            • 1812
                            interesting, i didnt' know the factory system used vacuum, I assumed it was 12v like the system in my corrado... very simple too, 2 motors and a switch :)
                            Chris
                            90 Corrado/91 M3/01 M5
