front running light does not work, but the bulb still works as a blinker
  • Kershaw
    • 11822
    if i turn my lights on, the running light (blinker) doesnt turn on. however if i hit the blinkers, it flashes normally. so i know its getting power, but i guess its not getting power running l
    also, my taillight went out. its not the bulbs, i tried swapping them around. no dice. i bought new bulbs for nothing..
    both are on the drivers side.
    i also found 2 fuses that were out, 7.5 amp ones, but if it were a fuse wouldnt both sides be out? kind of at a loss. i'd go get the fuses but im here at work. i tried grabbing fuses from my rx8, but it uses the newer smaller style fuse. :/
    its raining, i need my lights and i dont want to be pulled over. hlap plx.
    AWD > RWD
  • accident
    • 7303
    if i remember correctly each side has it's own fuse.
    Moral of this story?
    • kronus
      • Apr 2008
      • 13032
      It's a dual filament bulb. One of the filaments is used for the running light, one is used for the flashy bit. Either one of the two filaments burned, or greg is right and a blinker fuse burned.
      cars beep boop
      • Kershaw
        • 11822
        neither filament is blown. i replaced the bulb. and swapped the bulbs to the other sides.
        if each side has its own fuse, accident/greg is right.
        AWD > RWD
        • DaveSmed
          • Apr 2007
          • 1407
          accident is correct. Fuse 22.
          -Dave
          2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
          Need some help figuring out the ETM?
          • e34john
            • Apr 2006
            • 3599
            accident is right. safety thing, unless you are really unlucky and blew both fuses.
            • McGyver
              • 4636
              if you are running the stock fuses you might not be able to see that one blew cuz it could have just been a hairline break. goodluck!
              • Kershaw
                • 11822
                it was blown. the other fuse that was blown was for my gauge cluster. it took me about 10 miles of driving to realize my tach was working again. haha.
                all good now. thanks all.
                AWD > RWD
