Euro Smiley Wiring
  • Acehye559
    • 1033
    Euro Smiley Wiring
    I just got my Smileys in today and I've been doing some research. My car has sealed beam headlights and I want to put the smileys on. I found the following link and it seems like its the one that makes most sense.
    I also came across this link as well,
    http://bmw.e30tuner.com/articles_eurolight.php
    Is there anything else I need to know or am Missing? Also smiley headlights take H1 bulbs right? Thanks
  • McGyver
    • 4636
    Thats exactly how you do it. And yes, they are H1 bulbs.
    • Acehye559
      • 1033
      Thank you
      • Als E30
        • Feb 2007
        • 2
        Does anyone have a favorite hot fuse. In other words a fuse that I can wire my driving lights to so they will be on when the car is running, and turn off when the car is turned off. I really dont want to wire to the side markers. Dont want to turn them on and off. Thanks.
        • EN318isPDX
          • Oct 2007
          • 4373
          OP: Don't forget to jump pins #30 together from the high to the low beam relay otherwise your low beams shut off when you turn on the highs!
          If you wire them in as side markers they will come on when you turn on the runners aka 1 click. Would be a pita to wire them into accessory but if you want to run the wire good luck!
          • Acehye559
            • 1033
            Where can I find the plugs or pigtails that plug into the smileys? The elipsoid ones won't work right? Would the fog lights plug work?
            • Als E30
              • Feb 2007
              • 2
              The dealer has them.
              • 89AlpineM3
                • 548
                does anyone have the part number i need from the dealer, I bought a set of smiles but it came with no wiring.
