will 3 HIDs cause power problems?
  • ac3
    • Jan 2011
    • 121
    I'm installing 55w HIDs for lows and highs, and 35w HID fogs.
    Will I run into any voltage problems with these things? I'm beginning to worry about how this old car (89 325i) will handle them especially if I'm running an aftermarket stereo with amp and sub at the same time...
    BTW- I wasn't planning on using a relay harness or anything for the lights, especially since the battery is in the trunk.
    thanks for any input
    • 34834
    no except HID's in the highs probably won't last that long.
    • ac3
      • Jan 2011
      • 121
      Ok. Yeah I figured the highs might not last, especially if I ever flash them. But for cheapo vvme $35 lights I don't really care if they burn out, I wanted to give it a try.
      • straight6pwr
        • Sep 2004
        • 3450
        i ran 3x HIDs in my last car. no problems with them all on, but i wouldnt recommend firing them all up at once.
        dont flash the highs, youll kill them. ive heard that the ballasts have some sort of system built in where if they get flashed a few times they shut down to avoid blowing up or some such disaster.
        in the end, HID highs arent really that much brighter than regular highs. not worth it. just run HID lows and fogs with the brightest 9005 bulbs you can find for the highs. HIR 9011s should do the trick.
