Bzzzzzz, when I turn on my blinkers..
  • BMWLOCO
    • 129
    Just put in the new dash and when I do the blinkers, I get a bzzzz sound and no blinkers. Lights work, brakes work,, etc... My only problem is the turn signals... HELP!
    Thanks in advance...
    - Y2K M Coupe (DD, Track Rat)
    - '08 Land Cruiser (Family Hauler/Tow)
    - '90 E30 4/5sp. (DD/ Son)
    - '87 AW11 Mr2 (AutoX-Rally-Track)
    - '06 Royal Enfield Bullet 350 w/sidecar (weekend cruiser)
    Future
    - E92 M3
    - 88-91 M3 (maybe.. if I can find one, regret selling in 05)
    - Richie
  • Jaxx_
    • Dec 2009
    • 1880
    sounds like you need a new emergency flasher switch or relay. I forget the exact circuit but yeah... something along those lines.
    • Broom Broom
      • Jul 2011
      • 286
      bee under the bonnet?
      - 1987 325e m20 6cyl manual -
      • reelizmpro
        • 9556
        Remove the bottom cover from the steering column and tap the relay. Pretty sure the buzz is from the relay. It could be the relay itself or a bad contact/bulb somewhere.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • bmwguy325is
          • May 2011
          • 1263
          Its totaly bees. watchout man
          sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
          The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
          • ruqknuf
            • Jul 2009
            • 378
            This just recently happened to me during the dash swap. If its anything like what i did - I had the wrong harness plugged in on the rear defroster and hazard buttons - switch 'em - should solve the problem.
            Leave Feedback here:
            http://www.r3vlimited.com/board/showthread.php?t=261541
            • cbouchez
              • May 2007
              • 2789
              +1^^^
              Follow my IG @bouchezphotography
              • reelizmpro
                • 9556
                yea probably what it is since he changed the dash.
                88 M3 - LACHSSILBER
