Depo Euro Smileys Smoked
  • Robert
    • Dec 2010
    • 3770
    I have a quick couple questions about them for anyone that has a set of these lights.
    When you tap on the front of the lenses , does the whole light move a little?
    Also, how do you wire up the highbeams?
    I recently got a set of these and i tap on the front of the lenses and they move a little causing the light to move as well.
    Robert
    • 37833
    What do the high beam plugs on the lights look like?
    It's probably normal for them to wobble, they're Chinese. ;)
    Grover Beach, California
    BimmerHeads.com
    • Liquidc3lls
      • 22
      Another DEPO hater, anywho i just got a set aswell, got em in last week, so far they have been flawless, but yea i never did that tap thing, but at the moment i have not noticed or seen any wobble come from the headlights, as for wiring the high beam, its quite simple, if you are moving from Sealed beam to Euro's Ellips, it a matter of finding one ground one power and eliminating the third wire that the sealed beam needed. i did notice the wires that come with the headlights absolutely useless and the ammount of connectors and adapters needed is absurd. i just hard-wired everything with no euro connectors, it just seemed unreliable with so many adapters and connectors getting corroded or broken. good luck buddy
      here is a DIY for sealed to Euro
      Convert your BMW E30 to Euro smiley headlights from sealed beams or US ellipsoids - wiring, connectors and what bolts straight up.
      cheers
      • Cronopoulos
        • Jul 2011
        • 2187
        I just went out and tapped on mine with them on, no wiggle what-so-ever.
        Project log -- DIRTY 30
        2.7i * Megasquirt tuned * E85 powered
        • Robert
          • Dec 2010
          • 3770
          I get a lot of wiggle when i tap on my the light moves.
          • Liquidc3lls
            • 22
            same here, i just went and tapped. no movement! u have an odd problem my frnd
            • IRON-E
              • 16548
              No comprende...?
              @IRON-E30 aka Edwin:D
              • Robert
                • Dec 2010
                • 3770
                just tried again. I faced my car towards a dark wall.. tapped the lenses , it moves quiet a bit. If i grab the whole lenses and push down with a little force it will move the light about an inch or two on the wall and go back to regular position...
                • Kev
                  JMP Autowerkz
                  • 1575
                  I hate Depos they make Iron-e car look good.
                  If it doesnt vibrate when driving don't worry about it. :pimp:
                  Originally posted by IRON-E
                  No comprende...?
                  Sos pendejo seroti!!!
                  You mad?
                  "Hard Work Pays Off"
                  1991-bmw 325i (R3vvd)
                  1990- 325 (mpowa)(GC)(track)(beast)
                  1988- 528e (daily driven when track car broken)
                  • davem
                    • Jun 2010
                    • 705
                    well these head light assemblies are put together pretty simple, just take a look and see what the problem is...
                      • 37833
                      Originally posted by Liquidc3lls
                      Another DEPO hater
                      Yeah, because my 23 year old Hella lights are of better quality. Not only that I've got the same amount of money in to mine that depos would have cost and mine have been completely rebuilt with all new adjusters and clips.
                      Robert, as mentioned you should pull them out and see if something isn't clipped together correctly. Otherwise take them back to whoever you got them from.
                      BimmerHeads.com
                      • IRON-E
                        • 16548
                        You mad?
                        Nope, not mad black guy........
                        Originally posted by MR 325
                        Robert, as mentioned earlier you should pull them out and see if something isn't clipped together correctly. Otherwise take them back to whoever you got them from.
                        +1 on this, you've only had them for days, right?
                        • Robert
                          • Dec 2010
                          • 3770
                          I'll have to take them back to where i bought them! I've literally only have had these lights for less than a week!
                          • Blackout
                            • Apr 2011
                            • 4130
                            DEPO is another term for SHIT in my dictionary.
                            I would rather stick to OEM US spec projectors than buy DEPO.
                            I can see why even smart people fall for it. They look so dang nice and shiny in the pics and a month later, you find broken ends and moisture behind the lens.
                            Ya take them back Robert.
                            » PARTS FOR SALE
                            » TRANSACTION FEEDBACK
                            • Mars_e30
                              • Feb 2007
                              • 304
                              I have a set of the DEPO smileys on my car and had the "wiggle" issue.
                              On my case, the cause was a loose adjuster. One of the low beam adjusters goes through a piece of plastic that attaches to the headlight bucket. I think it twisted loose when I was adjusting the lights. I gave it a quarter turn back into it's hole and all is well.
