City lights; parking light only ! ?
  • ruqknuf
    • Jul 2009
    • 378
    After much research I've had no luck with finding my answer. I would like to have my citylights turn off when I turn my lowbeams on.
    Leave Feedback here:
    http://www.r3vlimited.com/board/showthread.php?t=261541
  • blazinxpk
    • 839
    im assuming you dont like the look of both lights on at the same time?
    also, it might help to state how the city lights are wired up? side markers?
    • reelizmpro
      • 9557
      Then wire the city lights independently.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • ruqknuf
        • Jul 2009
        • 378
        Correct, not a fan of both at the same time. Citylights are currently wired to the sidemarkers.
        • DaveSmed
          • Apr 2007
          • 1407
          Easiest way is disconnect the city light ground wire from the sidemarker harness, and connect it to the low beam positive wire.
          (assuming your running halogen bulbs)
          -Dave
          2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
          Need some help figuring out the ETM?
            • 37833
            Just an FYI, in Europe the city lights ARE the parking lights and also stay on when the headlights are on.
            Grover Beach, California
            BimmerHeads.com
            • ruqknuf
              • Jul 2009
              • 378
              running HIDs
              • DaveSmed
                • Apr 2007
                • 1407
                Hmm. Well, it might still work. Give it a shot, worst that will happen is that the city lights won't light.
                -Dave
                • E30Brad
                  • Aug 2013
                  • 84
                  Can the citylights in the smiley's be wired up to be a running light and a flashing signal just like the signals in the front of the bumper? Or only one or the other?
                  • Scootsk
                    • Jun 2017
                    • 11
                    Yes just hook the city light to the front directional
                    • E30Brad
                      • Aug 2013
                      • 84
                      Well, there is a running light wire and a flashing wire. So do you have to tap into both power sources and then install a dual element city bulb? its a late model if it makes a difference.
                      • ELVA164
                        • 4861
                        I'd be surprised if there was a bulb that size with two filaments.
