Foglight lens removal without destroying it
  • parkerbink
    • Jun 2004
    • 10137
    How the hell does this thing come off? I tried the oven which worked for smilies, I have had it boiling for twenty minutes nada. Any ideas?
    Thanks
  • Jordan
    • 12907
    Oven would be my only idea?
    How hot and how long did it take to get my lense off?
    https://mtechniqueabs.com/
    • parkerbink
      • Jun 2004
      • 10137
      Yours was the third I have done, it took less than 10 minutes at 250 and came off easily. I had the fog in there for 30 minutes at 300 and nada. (after 10 at 250 did nothing and I let it cool before trying again)
      Damn thing has been boiling for 45 minutes and nada. My wife is thrilled.
      Foglight soup anyone?
      • Hatchman
        • Mar 2005
        • 1425
        I tried using a soldering iorn around the seal... lol
        I ended up smashing my lense and saving myself the hours of work
        • UNHCLL
          • 8789
          Stefan/Jordan,
          where do you order replacement lenses?
          Thanks,
          CL
          Below the radar...
          • Jordan
            • 12907
            Well....
            As far as replacement 88+ foglamp lenses go, your only option is the acrylic Mr.Lens ones.
            For all ellipsoids you have Mr.Lens again as an option. Recently a completely crystal clear replacement lense has become available, made entirely of glass.
            Seems to be every bit the same dimentions as the original Bosch/Hella lense, but without the "ribbing" etc on it, and of course not ECE or DOT endorsements.
            I see absolutely no reason why these cannot be used in the low beams, as the ellipsoid doesn't give a crap what its shinning through. If anything the pattern should be that much more pure with nothing in its way.
            Downside being that the ribs do hide somewhat unsightly innerds of the lamps.
            • parkerbink
              • Jun 2004
              • 10137
              Boiled it for an hour, seemed to have some give, broke it :(
              Oh well life goes on. Chris like Jordan said Mr Lens is the only place other than ebay but the guy has lots of negs.
              • UNHCLL
                • 8789
                So I can order these from BMP?
                $35 for the pair and they should work as replacements? I'm not to worried as they only need to last for the winter.
                Thanks to both of you for the help.
                Below the radar...
                • BENdashdash
                  Tom is not my friend
                  • Aug 2004
                  • 2506
                  Have any of you tried a heat gun? That's what I'm going to use when I replace my fog lenses.
                  • parkerbink
                    • Jun 2004
                    • 10137
                    I don't have one but I doubt it will work (I wanted the lense intact as the issue was the reflector was rattling around and the lense while pitted was ok) the heat of a pot of boiling water while not as much as a heat gun was not hot enough and the heat gun would only be hot on the spot you are pointing it at and you need the whole lens free not just one spot.
                    • BENdashdash
                      • Aug 2004
                      • 2506
                      ehh, the lenses arent that big... are they just glued on?
                      • parkerbink
                        • Jun 2004
                        • 10137
                        Thay are connected with some kind of super glue/silicon that barely budged after an hour at full boil. Let us know how the heat gun works out for you.
                        • Q5Quint
                          • Jan 2005
                          • 725
                          i broke mine out with a screwdriver and used some clear rtv to stick the new mr lenses on. took about an hour and 15.
