Ellipsoid Conversion
  • Skafrog
    • 1732
    So I have a sort of nagging question. How do you get the "flash" feature (pull back on high beam lever, highs illuminate so you can flash them) for the high beams once you have converted to ellipsoids from sealed beams?
    Or is this not an option?
    NASA MidSouth TT Director / GTS2 #018
    Mods: Coastal PS Fluid, 10w40 Oil
    Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
  • Jordan
    • 12916
    Should just work as normal.
    Mine does. Only the highs come on.
    https://mtechniqueabs.com/
    • parkerbink
      • Jun 2004
      • 10138
      Same here
      • bmwm3n528
        • 3654
        Yeah, don't think the fact that it was a sealed beam car makes a difference. Only difference, obviously, is your lows switch off when your highs are on.
        Trevor Ely
        '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
        '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
          • 34839
          works fine for me. and if you wire it right your lows stay on with your highs (and your fogs, too).
          • Skafrog
            • 1732
            Alright, should have made it more clear.
            When the lights are off, how do you get it to flash?
            I have it all wired correctly, and the lights function correctly, except for this nagging problem.
              • 37833
              Strange, mine work fine
              Grover Beach, California
              BimmerHeads.com
              • Skafrog
                • 1732
                alright, must be my e28 stalks then.
                Never mind.
                  • 34839
                  yeah, my highs come on if I flash with the lights off.
                  • bmwm3n528
                    • 3654
                    You are pulling back on the stalk, right? :D
                    Trevor Ely
