Grease like goo on marker light contacts
  • parkerbink
    • Jun 2004
    • 10138
    I had a marker out (front in bumper surround) so figuring it was the bulb I took the bulb out. The contact end and part of the bottom of the bulb were covered in a tan grease like material that was apparently insulating the contacts from the contacts on the connector. After I cleaned it off the light lit.
    WTF is it? where does it come from? How do I prevent it's return
    Merry Whatever you celebrate.
  • StereoInstaller1
    GAS
    • 22679
    Stefan, that goo has 2 purposes. 1, it helps keep corrosion away, mostly by waterproofing. 2, it helps control vibration, which I am sure you can imagine really pisses off the tiny little filament in the bulb.
    What I would guess (assume?) is that a tiny bit of corrosion happened on the connections in the socket. You removing the bulb and reinstalling it made better connections.
    I always smear wheel bearing grease on my bulbs before I re-install them. On 4X4 or nasty weather rigs or boat trailers, I squirt a wad of silicone (GE Silicone II, 100% stuff) in the socket before I install the bulb. Totally waterproof, they last for years. I learned this trick from an installer from Alaska. He shot silicone into butt connectors before crimping. Hell of a trick!
    Happy Harmonica, Seasoned Greasings!
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • parkerbink
      • Jun 2004
      • 10138
      Gracias, Feliz Navidad!
      btw I think your sig guy needs a hand (or 2)
      • Addissimo
        • Mar 2004
        • 1820
        its dialectic grease if you want to know exactly what it is...
        Doing something M50 related? -> http://www.addissimo.com
        On Myspace? ->http://groups.myspace.com/r3vlimited
        BF2142 SN = BillyGoose
        • E30junky
          • Dec 2005
          • 5
          I had to put greese on the plug connector for one of my turn signals.It kept corroding and not makeing a good contact.The dab of greese in there fixed the problem.
