Dual Hid Kits. Problems? tips? Etc..
  • UniqueBmw
    • Dec 2005
    • 52
    I noticed that C//M has dual hid kits. the manufacturer said to me that i would need a type of inline battery so that on start i do not overload my wairing. DOES ANYONE KNOW WHAT THIS SHIT IS.. HIDs are uspposed to require a good bit of power during start up correct? But during constant running time they use less wattage then original Halogen? So why would i need EXTRA POWER.. WHat problems has anyone has installing dual HIDS conversion. And info would be greatly apprecaited. And it would probably help alot of people with HID questions thanks
    Mods to come:IS LIP RyanG(scored) MTechII Rear (SCORED) Shadowline (soon) Tint (soon) Umnitza HLConv w/HID ( wow am i broke yet)
  • PaulZ
    • Aug 2005
    • 118
    not sure, but I'm in the process so I'll let you know when I'm done...
    • parkerbink
      • Jun 2004
      • 10138
      OEMs only use hids in lowbeams. I think this is because high HIDs would just be too bright.
      • Ryan Stewart
        I Love Miatas
        • 8978
        No its because you cant flash HIDs. They have a long startup time. BMW uses HID in the highs but what they do is move the already lit bulb down in the housing below the cutoff so it shines straight out.
        If you pull on the stalk to flash then it just illuminates standard halgoens in the middle.
        And yes, they use a shit load of power at startup but once running use almost nothing. Mine dont even flicker when I start the engine like the halogens did.
        Im now E30less.
        • parkerbink
          • Jun 2004
          • 10138
          I sit corrected.
          • Jordan
            • 12916
            Chris also has HID lows and HID fogs.
            If its such a problem (never heard of this bulshit) then just don't start both at once...
            https://mtechniqueabs.com/
            • Ryan Stewart
              I Love Miatas
              • 8978
              Word, although unless you get long wavelength having HID fogs is pointless. I was thinking about a 3400k kit but decided that was pointless as I never drive the car anymore anyway.
              I think most manufacturers recommend an inline relay instead of using the regular headlight wiring because they dont know how the vehicle was setup. That way it pulls power directly from the battery. Ive been running fine on my regular headlight wiring and relays for a couple years now.
              Im now E30less.
              • 92 mtechnic cabrio
                • 4907
                HID fogs are okay in E30 foglamp housings? I was told that HID bulbs would melt the housings
                R.I.P 07/01/09 - 04/23/10 :(
                • Ryan Stewart
                  I Love Miatas
                  • 8978
                  My HID bulbs run a hell of a lot cooler than the old halogens. You can tell it when you touch the lense.
                  They are 800 degrees in the capsule but there is a vacumm between the capsule and the bulb so it stays cool.
                  Im now E30less.
                  • PaulZ
                    • Aug 2005
                    • 118
                    well the HID's in the fogs leave the light extreamly fragmented as I originally thought, so now I'm going to have to fabricate an ellipsiod into the fog and see what happens...should be a fun project
                    • Mystikal
                      Wheel Fitment Expert
                      • 9602
                      Late model fogs have ellipsoids, and have a crisp HID cut-off, just for people curious.
                      • kylebes1
                        • May 2004
                        • 2804
                        What brands do you guys have? Hella, Phillips, Mc
                        • PaulZ
                          • Aug 2005
                          • 118
                          The set I just got for my fogs are Mc's, the low's are some no-name brand but have had no problem with them yet...
