Headlight problem- HELP!
  • entiatfan
    • Mar 2013
    • 115
    I purchased a 90 325I.It had a lowbeam out,so I went to change it and found a problem.Looks like someone hacked out the projectors and put in sealed beams?Fixed the twisted and taped connections,and it pops the fuses every few days? Do sealed beams take a different relay? Are my sealed beams stock? Man I just don't know? Thankyou
  • bimmer2288
    • Feb 2006
    • 273
    Pictures might help.
    If fuses keep popping there may be a reversed polarity or a wire getting crossed somewhere. Fuses blow when there is a surge of current to protect the components.
    You may also have an incorrect fuse installed, double check that and make sure its correct amperage.
    If you've got more wires coming from the car than you have to mate from the sealed beams, then its possible that the ellipsoid lights came stock and because of damage, the PO replaced them with a cheaper light.
    I'm not 100% on any of these, but its a start.
    • entiatfan
      • Mar 2013
      • 115
      Hey thanks! My 16yr old drives it and said they seemed to go a little dim,then back to bright this week coming home? It sounds like there is a plug of some kind under the coolant tank? It is the power to the headlights, and can get corroded? I will check when it gets home.
      • reelizmpro
        • 9556
        90 325's came with sealed beams.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • entiatfan
          • Mar 2013
          • 115
          That answers one mystery reelizmpro! I cant figure out why the lightplugs were cut and twisted together then?I just figured the fancy ones were cut out! Thanks for the input!
          • reelizmpro
            • 9556
            You should have 3 wires for low beams instead of 2, right?
            88 M3 - LACHSSILBER
            • entiatfan
              • Mar 2013
              • 115
              Yes I do. Gunna check the relays in the morning.Also the connection under the coolant tank?!
              • entiatfan
                • Mar 2013
                • 115
                Figured it out.Voltage regulator was bad.The voltage was spiking at almost 20 volts.Replaced the alternator,hope it did the trick!
                • claysones
                  • Apr 2013
                  • 58
                  Do you know which fuses are the low beams? i.e. outside lamps?
