Switching hi-powered lights with high beams
  • lcoleman
    • Jan 2009
    • 331
    Hi all,
    I have recently undertaken a project for night driving in the mountains. Basically, two aircraft landing lights mounted to the bumper.
    Currently, this setup is wired with a standard 30A relay and triggered by a simple switch. This is simple, but it is difficult to dim high beams and fumble around for the switch when passing any (very sparse) oncoming traffic. I want to make these lights triggered by the dimmer switch so they are only on when the high beams are on.
    Looking at the wiring diagram:
    It looks like the dimmer switch gives a switched ground signal on the white wire going through C202 to pin 85 of the high beam relay. So, in theory I should be able to use that as the gnd side of the switch for my aux lights....but, that doesn't work. Test light lights up on that wire, too?
    How can I wire this? What am I missing? I can't see anything in the fusebox, all the relays are wired to some kind of board and I can't determine what goes where.
    Thanks in advance.
  • Poorboyz
    • May 2012
    • 2117
    What size generator are you putting in the trunk for when you run the lights?
    joke
    Rebuilding since 07/06/2016
    Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
    Poorboyz Feedback Thread
    • DER E30
      • Sep 2013
      • 2349
      Well, I would wire my extra awesome blinding lamps into the WHT/VI wire that powers the actual high beams,(or the 87 of the high beam relay) and run that to the 86 of my relay that controls the landing lights. Ground the 85, 30 to power, 87 to lights, ground lights, and done.
      I was thinking of doing this myself, only on a roof rack. I would probably run a full rack with some form of wood boards (maybe balsa for lightness!) running between the bars with possibly 4 KC daylighters (or something like that) on the front, wires running through the popped “up” sunroof. I think it would look pretty sweet, and be removable.
      -Christian
      • DER E30
        • Sep 2013
        • 2349
        joke
        Well you could mod the diff input to have an alternator belt drive!
        -Christian
