Brightest non-hid bulb for ellipsoid's?
  • M-technik-3
    • 18946
    basically a one way valve for moisture when it's hot it opens and steam goes out.
    • digger
      • Nov 2005
      • 6162
      Anyone used OSRAM 12V 55W H1 night breaker replacement bulbs?
      OSRAM are what you get when you buy a bulb from dealer so should be a quality brand
      http://www.amazon.com/H1-OSRAM-Break.../dp/B00GPJPBBI
      • ELVA164
        • 4861
        Get clear bulbs, they'll be brighter. Tinted bulbs of any type will be less bright than the clear alternative.
        • beta14ok
          • 283
          Originally posted by M-technik-3
          Good old cibie, hella's bosch glass light pre ellipsoids will take a 100W H1 with ease.
          While this is true, the wiring in the whole circuit may not be up for handling the current bump of using higher watt bulbs (read 100 watt). What usually gives out is the circuit board of the fuse box.......the underside!.....which means ya gotta pull the board out to fix it.
