91' e30 with sealed beams?
  • Rouvld
    • Sep 2014
    • 569
    I just noticed on a 91' e30 that I'm thinking about picking up has sealed beams. I thought all car 89 and up came with ellipsoids? Or was it an option? Also are ellipsoid headlights plug and play on sealed beam cars? My current 89 has ellipsoids so I was a little curious as to why this 91 didn't have them.
  • audiquattrot
    • May 2008
    • 3836
    I've owned two 1990 ones, and both came w/ sealed beams.
    No they aren't plug and play. You would need the pigtails for the projectors.
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
    • Rouvld
      • Sep 2014
      • 569
      Damn, was hoping they'd be plug and play. I guess if I buy the car I could always use the set up out of my 89 that has ellipsoids.
      • Stanley Rockafella
        • Aug 2011
        • 4062
        BMW cheaped out on the 89+ e30's with sealed beams to save $$ as the ellips setup was too costly.
        • rcsoundn1
          • Nov 2012
          • 3361
          my 89 has elips? what models got sealed v elips?
          • ELVA164
            • 4861
            All pre-'88 cars (this all applies to the U.S. of course) came stock with sealed beams. All cars in '88 (and I believe '89?) had stock ellipsoids. '90+ had stock sealed beams. '89 may have been a transition year, though.
              • 34844
              by now most or the original lenses would be pitted and / or cracked, the reflectors oxidized and basically not that great anymore. There are plenty of better lighting options these days than a worn out set of lights from 1988, it's not a big deal..
              • Das Delfin
                • Sep 2014
                • 2293
                Ellips are not plug and play on sealed beam cars but Hella H4 conversions are and are a major improvement from the standard sealed beams. If you were going to go with ellips I would buy an HID retrofit kit with new projectors from one of the guys on the forum. just depends how much money you want to spend. H4's are way cheap compared to a proper HID setup
                • Rouvld
                  • Sep 2014
                  • 569
                  Yeah that's my plan is to go ellip's with and HID kit. I actually ordered and just got new oem ellipsoids for my car (an 89) but I'm thinking of buying an newer e30. So if I buy the 91 I'll be doing an HID kit on the brand new OEM ellipsoids and retrofitting them to the 91.
                  • reelizmpro
                    • 9556
                    Early half 88's had sealed beams so there is a start date sometime in 87 and ended sometime in 89. So late model year 88 upto 90.
                    Per Real OEM...
                    01 TWIN HEADLIGHT LEFT 1 09/1987 - 06/1989 63121385797 $442.71
                    01 TWIN HEADLIGHT RIGHT 1 09/1987 - 06/1989 63121385798 $442.71
                    So here's the definitive answer based on production date.
                    88 M3 - LACHSSILBER
                    89 M3 - ALPINEWEISS II
                    • ELVA164
                      • 4861
                      ^ Good call checking that site.
                      • Savagefurai
                        • Apr 2011
                        • 970
                        Hmm...
                        I have an 88 seta that came to me with sealed beams. My thought is that they were replaced at some point but I've since changed them out for elips.
                        My 87 has stock sealed beams as well.
                        Sent from my SM-G530T using Tapatalk
                        Currently without an e30. Will probably die soon.
                        • ELVA164
                          • 4861
                          Originally posted by Savagefurai
                          Hmm...
                          The wiring harness would really tell you which type were originally installed.
                          • Red46
                            • 1151
                            Definitely.
                            The sealed beam "low beam" is dual filament so there would be three wires (ground, low, high) going to the low beam. When the high beams are turned on the low beam illuminates the high beam filament in the low beam bulb.
                            Ellipsoid low beams are single filament so they only have two wires (ground, low). They just stay on when the high beam is activated.
                            • Kevinl
                              • Oct 2012
                              • 897
                              Like what?
                              All i know of is elips, smiley & smoked hellas
                              1989 BMW 325is Lachsilber metallic 5 speed
                              2007 BMW 335i KARMESINROT 6 Speed manual
                              2011 BMW X5 35I
