Separate Rear Light Housing
  • gespinal0301
    • Jan 2011
    • 317
    Is it possible to separate them?
    My Daily Driven 318is
  • Mo Brighta
    • 431
    You can separate the bulb carrier from the lens, you have to do this to replace bulbs; but you cannot separate the lens from the frame, it's bonded permanently on assembly.
    Why do you ask - are you trying to get more light out of it? If that's your aim, send me an email or PM, I can help.
    Andy
    Andy says "Be Seen, and Not Hurt!"
    Lighting Upgrades front and back for 2002, E3, E9, E10, E12, E21, E23, E24, E28, E30, E32, E36, E39, and more.
    Tail Light Improvements keep them off your tail.
    Headlight protection saves headlights from breakage.
    • gespinal0301
      • Jan 2011
      • 317
      Andy
      I was going to design some pcb for leds, but I just wanted to know if there is another way of opening them without taking a hot blade to the assembly
      • Kershaw
        • 11822
        Using a dremel will allow you to cut the openings exactly to the size you want. That's what I did when I converted my rears to LED.
        AWD > RWD
