will these blind people.
  • moatilliatta
    • 6151
    Power Bulbs specialise in bringing you only the best, original equipment quality car headlight bulbs and other car lights from leading manufacturers including Philips and OSRAM.
    i dont want to blind poeple with my fogs.
    but if there aimed corectly does it even matter?
    and these are the best H1 bulbs without blinding people right?
    if not what is the best H1 bulp for output
    I also plan on using thses as the high beam lights. and yes or no on the low beam?
    your thoughts?
    @Zakspeed_US
  • smonkbmw
    Professor
    • Jun 2006
    • 4549
    you can have every light on your car aimed properly and still have people flash you.
    • netcsk
      • Apr 2004
      • 1609
      dont run with your foglights on. There is no reason to drive around with them on. Treat them like high beams... That's my opinion at least.
      • moatilliatta
        • 6151
        i enjoy driving w/them on. rain or shine. but it really made me mad when i had to use them w high beam in the rain. and they didnt come on w/ high beam.
        why do you say treat them as your high beams?
        @Zakspeed_US
        • NC325iC
          • Mar 2004
          • 6565
          not treat them as your high beams but like high beams use them only when needed is what he means,
          i however think you should have them on anytime the parking lights are one, mainly just for looks but thats just me
          • Van Westervelt
            • 9365
            I usually always run with my lows on and fogs at night. Small car with lots invested is an easy miss for other brain dead drivers. Then if they hit I'd probably end beating the ish out of them. So I turn my lights on for higher visibility.
            • blueapplesoda
              • Dec 2005
              • 1904
              Driving canyons i need that extra width of light thta straight projectors don't give, hence fogs step up and fill in.
              • NC325iC
                • Mar 2004
                • 6565
                +1 gotta see the sides, dont want a deer to run into you (and yes i mean run into you)
                • moatilliatta
                  • 6151
                  yeah my uncle was driving his new cadillac sts and he slamed on the brakes to avoid the deer then once he stoped the dear jumped into hes car and fucked it up....
                  @Zakspeed_US
                  • ZinRot325i
                    • 291
                    Yeah my friend had an 86 325e and he relocated the foglights to the outside of his massive metal front bumper for the express reason that he needed to have better side lighting...so he could see the deer.
                    Saved our ass a bunch of times.
                    They're rampant around here.
                    :wgaf:
                    • moatilliatta
                      • 6151
                      where is around here. sounds like is way out in nowhere....
                      @Zakspeed_US
