Check panel lit but brake lights functioning
  • ttrousdell
    • Nov 2009
    • 1770
    My brake lights are in good working order but the check panel continues to stay lit for a brake light fault. Any ideas?
    The Build:
  • E30SPDFRK
    • 5709
    Check the side marker lights in the bumper, they can throw the light for the brake light circuit. If they’re all working, pull all the bulbs, clean them and the housings, and apply dielectric grease to everything.
    Byron
    Leichtbau
    • ttrousdell
      • Nov 2009
      • 1770
      That’s prob it. One of my side marker lights has been out for a while. Will change and see if that does the trick.
      The Build:
      • ELVA164
        • 4861
        Also make sure you're using nickel bases on the bulbs (silver color). They have a different resistance than brass and can mess with the check system.
        • Gregs///M
          • Mar 2012
          • 2459
          The transistors that control the LED's can get stuck after 30 years, so keep that in mind, the check panel system can start to fail
          Owner - Bavarian Restoration
          BMW and European Electronics Repair and Restoration
          www.BavRest.com
          My Feedback Thread
          Our Facebook!
          Follow our Instagram!
          • e30davie
            • Apr 2016
            • 1788
            yer my check lights are all over the place. I'm considering cutting power to it. The brake light one is always on and the coolant one comes and goes. Wouldn't be an issue if you didn't start flashing check on the dash on startup.
            • ttrousdell
              • Nov 2009
              • 1770
              Side markers all functioning, bulbs all nickel base and contacts cleaned, check panel swapped from another car. problem persists. I have heard the brake light switch can fail. Will look at that next.
              The Build:
              • PDXPeter
                • Apr 2018
                • 225
                If the switch failed then the lights wouldn't come on. Did you check the 3rd brake light? It has its own internal check relay that can be problematic.
                • earthwormjim
                  • Jul 2014
                  • 434
                  You might have issues with the check control relay itself. Poor contact, cold solder joint cracks, or worn out reed relays.
                  I suggest you jumper across the brake light check relays (they're the two with less wire turns), and see if the check light persists. If so, then you have issues elsewhere in the check system.
                  The brake light check system is extremely finicky. If there is even the slightest delay, or the current drawn is even slightly too low, the light will come on. The reed relays are seriously underwound in my view by default. There is less than 100mA of current margin on them.
                  • slippery
                    • Nov 2011
                    • 377
                    Where is this check control relay located??
                    • doctorx
                      • Mar 2019
                      • 65
                      in the drivers rear trim panel low... i believe. I had the same problem on my vert. It turned out the circuit board controlling the 3 brake light had corrosion and bad wires. I had to resolder and rewire the controller then it worked. I am not sure yours has such a beast.
