LEDs..will they throw an error code?
  • spyder918
    • Apr 2019
    • 144
    I'm looking to possibly install some LEDs in the license plate and reverse lights. Does anyone know if this will throw any error codes?
  • reelizmpro
    • 9556
    yes, the check control relays need to see some resistance. For the plate lights, I ignored the check light but then discovered that one of the LED's was in fact completely out and the other was blinking. That's why I removed mine and went back to new filament bulbs. The look wasn't worth it to me. You can run them in the reverse lights as they are not checked.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • doctorx
      • Mar 2019
      • 65
      i run leds, but can only in a few areas. To me it is a safety thing since incandescent rear bulbs are not that bright. I was able to run them in turn, reverse, and 3rd taillight with a resistor. All corner markers are led. The front turns are switchback leds. Headlights are leds, but required resistors to work correctly and not piss off the check computer. They are in proper projector housings. Fogs are leds for now, but may switch those out for something else. Interior bulbs are all led except for low fuel and temp bulbs. I had to put incandescents back in the license plate bulbs. Would not work with leds even with canbus resistor types.
      • mach schnell
        • Apr 2008
        • 1059
        LED’s are so much brighter than incandescent bulbs, I love how bright they are in my E30. But the check control error is annoying. I wish someone would make up an E30-specific set of LED’s with resistors.
        • e30davie
          • Apr 2016
          • 1788
          I just unplugged the check control computer thing....no error on the dash:)
          • PDXPeter
            • Apr 2018
            • 225
            Thats my plan...
            You can also get a solid state relay for the turn signals so they don't hyperflash.
            • RCBFL
              • Mar 2019
              • 4
              LED's work on exterior lights except for license plate lights which sometimes turn on the check light. I'll probably remove mine.
              Member BMW Classic Car Club
              Member Ferrari Drivers Group Sarasota
              Member Porsche Club of America
              • spyder918
                • Apr 2019
                • 144
                Originally posted by PDXPeter
                Thats my plan...
                How do you unplug it?
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Pull the check panel down and unplug the connector.
                  They are talking about this:
                  • spyder918
                    • Apr 2019
                    • 144
                    Thank you!
