I am in the market for an H.I.D. kit for me IS. Here's my situation, i have a 90' 325is which as you all know came with the disgusting sealed beam lights. I was given a set of U.S. ellipsoids from my friend and installed those. Everything went smoothly with the wiring. I then proceeded to buy a set of DEPO smileys which i am very happy with but the only problem with the DEPOS was that the wiring was plug-n-play to the 9006 but the bulb in the actual headlight was an H1. So here's my question, if I buy a kit for a 9006 bulb type, will the bulb have to fit in the housing where the H1 sits? I.E. does the H.I.D. bulb lock into the headlight housing like the 9006 bulb or what? And if I do get the 9006 kit will i have to fabricate the H1 housing in order to ocomidate the H.I.D. bulb?
thanks
E30Fiend
thanks
E30Fiend
