Bought Depo Euro lights, need help
  • Rosica
    • Jan 2004
    • 240
    By accidently I bought a set of Depo clear euro lights about 6 monts ago. After have to fix a fatory assembly error, now I cant get the low beam bulb cap off. I turn as hard as I can but it wont budge, I just wanted to ask if it does twist off, and which direction.
    Thanks
    07 335xi Sport
    00 S2k
    01 A4 1.8t-Sold
    88 M3-Sold
    91 325iC-Totaled
    89 325iS - Sold
    87 325-Totaled
  • AC Nico
    • 3619
    turn left or look at the cap there is a word calls "lose" and another one called "fest" and a arrow. "lose" means that you can open it.
    *** For sale: euro stuff, BBS steering wheels, smoked tail lights, bunch of rare wheels (5x120 and 4x100) ***
    [/color]
    • e30Matt
      • 5077
      Depo quality... we'll only settle for bottom of the line!
        • 34827
        it will come off.. it seems like it won't and that you're going to break them, but it will.
        actually, you might break them.. heh. the plastic they use really sucks. :x
        • Ryan Stewart
          I Love Miatas
          • 8978
          IIRC on my Hellas its counterclockwise. Dunno if the depo are the same.
          So far the responses makes me fear the Depo.
          Im now E30less.
            • 34827
            it should be, they are pretty much exact copies of Hella only made with cheap garbage materials.
            • 325 eta
              • 472
              they twist off. after getting them off i grinded off the catch a bit so i can twist it off and easier. plus use some rubber cement on the seals to keep water out . i used this approach as a precaution. plus use some lube on the beam adjusters so its easier to adjust. hope this helps.
              • BavarianBimmer
                • 951
                Try with some WD40
                It has worked with my original '84 model with the metal caps
                1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
                1997 E36 328iT
                1990 E30 325iT 24v SOLD
                1989 E30 325i 2.7i M-Technic II SOLD
                  • 34827
                  heh, I'd be worried about WD-40 dissolving the plastic. :shock:
                  • BavarianBimmer
                    • 951
                    I will it try it immediatly on my Hella's now
                    but i don't think so
                    maybe the Depo ones are so crappy :roll:
                    I use WD 40 on the plastic of my ATV
                    1997 E36 328iT
                      • 34827
                      exactly. I'm not just talking out my ass here either, I have two sets :P
                      I guess they're just too easy to bash.. as soon as I can get a real set of hellas, I'll ditch the depos.
                      • gsbadbmr
                        • 129
                        There is ONLY 1 way to remove it properly WITHOUT breaking it. Take the whole light assembly out, and put it under HOT running tap water. Use a damp rag on top of the cap and turn it counterclockwise. After it opens put some vaseline around the inner part of the ring and you won't have to worry about it seizing up anymore.
                        -gsbadbmr
