Problems wiring euro ellips
  • ian e30 318is
    • Mar 2007
    • 1807
    I am having some trouble wiring my ellips. both the high beams and low beams work when i turn on the high beams but without the high beams on the low beams dont work. please help. hah. thanks.
    Ian
    ...and pics would help if they are available.
    1991 LS1 Swapped 318is
    Instagram:
    https://instagram.com/saltybeast/
    LS Build Thread:
    https://www.r3vlimited.com/board/for...s-e30-ls1-swap
  • JasonC
    Site Manager
    • 14451
    it sounds like you hooked up the wrong wire on the low beams. Leave the white with blue tracer unhooked on the low.
    1992 BMW 325iC
    1978 Chevrolet Monte Carlo
    • ian e30 318is
      • Mar 2007
      • 1807
      ok i will try that. i might be back on here if it doesnt. so you keep the wire just unhooked?? and is it the blue and white wire on the low beam??
      Instagram:
      LS Build Thread:
      • JasonC
        Site Manager
        • 14451
        yes, leave the white with blue unhooked (can cap it off if you want to)and the yellow with blue is the hot and brown is the ground. You have to do the relay jump for the lows to stay on with the highs. http://www.r3vlimited.com/board/showthread.php?t=59735 thumb through this thread and i believe it's in there.
        1992 BMW 325iC
        • ian e30 318is
          • Mar 2007
          • 1807
          ok thanks
          Instagram:
          LS Build Thread:
          • ian e30 318is
            • Mar 2007
            • 1807
            still dont work. I am stuck.
            Instagram:
            LS Build Thread:
            • thereisnoyun
              • Feb 2007
              • 2301
              let me guess
              let me guess, you had the original dual beam light?
              if so, you need to solder the relay together. Or else it wont turn on. Check on the forum on wiring diagram, I forgotten which one it was, since its been a long while.
