HID pics
  • lucky7
    • Jul 2005
    • 692
    #121
    DDM 55w 4500k with US ellipsoids.
    did the mod to utilize the highs and lows at the same time.
    -Dane
    diving board division, bishez.
    • dlmrun2002
      • Apr 2007
      • 808
      #122
      I got the same kit. After one side slow to turn on it seems better after running it for a week or so and comes on usually 1st try. The problem is now my hi beams look like yellow ass. I think I need to change those to HID soon.
      dlm ny
      • sector6
        • 909
        #123
        Originally posted by dlmrun2002
        ...The problem is now my hi beams look like yellow ass.
        dlm ny
        Roger that! I want to try some nice PIAA's for the highs. They might be a bit closer to the HID color at least. The Silver Star's I'm running now look like garbage. We'll see....
        • ADCD875
          • Dec 2008
          • 115
          #124
          How to do this mod?
          Can you explain the mod please?
          Thanks
          • rhett325i
            • Jan 2005
            • 575
            #125
            Thanks
            Maybe he means the relay mod for independent fogs?
            • Mo Brighta
              • 427
              #126
              Thanks
              Maybe I can help, I have something similar on my E28, which came with inner Highs and outer Hi/Lows, but lows were replaced with low-only lights.
              There is a diode protected relay in the low beam circuit that is grounded thru the high beams on low, and it's coil is backfed from the high beam relay output on high. This kills the lows (and fogs are set up the same too, I believe) when you switch the highs on.
              I have a set of instructions that redirects the ground path from the low beam relay so that it stays on at all times, would you like me to send you a copy?
              Andy, the tail light guy
              Andy says "Be Seen, and Not Hurt!"
              Lighting Upgrades front and back for 2002, E3, E9, E10, E12, E21, E23, E24, E28, E30, E32, E36, E39, and more.
              Tail Light Improvements keep them off your tail.
              Headlight protection saves headlights from breakage.
              • stumble_t
                • Aug 2009
                • 759
                #127
                when you go from sealed beams you have to either do a relay mod or use diodes to have them on at the same time.
                I prefered going diode here
                there are plenty write-ups on the relay mod
                [IMG]http://www.r3vlimited.com/board/
                • E30_(1st Musk)_
                  • 2008
                  #128
                  okay guys. im buying DDM raptors soon.
                  it saids i need 9006 bulbs. what is the difference between those bulbs and the H1/H2/H3????
                  • pinoy325i
                    • Dec 2009
                    • 127
                    #129
                    9006 would be plug-n-play for US ellips. H1 is for euro smiliess. just a difference in connectors.
                    1989 325i Delphin-Metallic
                    Fueled by faith! :)
                    • E30_(1st Musk)_
                      • 2008
                      #130
                      cool. last check. the US Ellips are the one's with the three niples?
                      • beybedba
                        • 517
                        #131
                        did anyone use DDMkits for the High Beam aswell?
                        • SimplyDope
                          • 1335
                          #132
                          I just noticed your plate for the first time :nice:
                          • Bishop
                            • 4913
                            #133
                            I know some people posted pics of the DDM 55w 4500K kits (lucky7) but does anyone have more pics showing light output at night and such? I just placed an order for the 55w 4500k kit to replace my 35w 6000k (which is now for sale).
                            PM me for detailing services in the Longmont / Boulder Area in Colorado!
                            Originally posted by DTM190
                            "fuck the kangaroo dude, his toilet water swirls the wrong way anyway, plus i never liked crocodile dundee or Steve Irwin and vegemite tastes like shit"
                            • craiggroves91
                              • Oct 2009
                              • 3024
                              #134
                              I want to see some more of the 55w 4500k and 5000k in Hella Smilies, I need to put my smilies in ASAP ( I have a sealed low beam out)
                              4500k will be more white than 6000k which would be blueish correct?
                              What about 5000k? white?
                              1989 BMW 325i SOLD
                              1998 BMW Estoril Blue e36 M3/4/5 SOLD
                              1987 BMW 325 (The Piece) SOLD
                              1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
                              • ak-
                                • 12422
                                #135
                                55w 4500 = white.
                                55w 6000 = white, with slight blueish haze.
                                1991 325iS turbo
