Hella Smoked Headlights Question
  • straight6pwr
    • Sep 2004
    • 3450
    Originally posted by evil_twin
    So i jumped #30 on low beams with #30 on high beams, and now they stay on. I don't really like it, kind of goofy lol.
    shouldnt matter, the point of highs is getting the most light on the road, why would you want to take away light and have your lows go off?
    • evil_twin
      • Nov 2007
      • 2965
      What? No. I don't like how ghetto that mod is. lol. Mine has been set up like that to stay on, but the sealed beams or something haven't. Idonno.
      Paypal: vdang5@gmail.com
      Delta Auto Care
      2875-C Towerview Road
      Herndon, VA
      703.435.1375
      My Feedback Thread: Evil_Twin
      • straight6pwr
        • Sep 2004
        • 3450
        what are you talking about the sealed beam hasnt? and jumping a relay isnt all that ghetto. its a simple electrical trick to get around extensive re-wiring.
        • evil_twin
          • Nov 2007
          • 2965
          With sealed beams, the low beams will turn off when the high beams are turned on. Ellipsoids don't turn off when the high beams are turned on.
          And putting a wire between 2 relays is ghetto. Im going to pull everything off and rewire it when I get some time anyway. Do it right the 1st time and you won't have comebacks.
          Edit: To each his own though. Im not bashing you for the way you look at things or anything. I just like everything being perfect.
          Delta Auto Care
          Herndon, VA
          703.435.1375
          • cabin
            • Dec 2006
            • 552
            No they don't. The low beams are dual filament, when the highs are activated, the high beam lamp will come on and the low beam's high will be on as well. That is how the sealed beams were on my 318is at least and they were the stock lamps.
            Also, I can understand wanting to rewire everything to do it "right" but you are wasting your time. Jumping the relays takes 10 minutes and it is not visible until you pull the relays out. There is nothing "ghetto" about it unless you use more wire than necessary and have it hanging out of the fuse box.
            -Justin
            Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
            • evil_twin
              • Nov 2007
              • 2965
              That was written incorrectly. But the car that I have now, has the hellas, and before it did have the seal beams. The owner before had the proper wiring so it was plug and play. When the high beams were on, the low beams would turn off, and the 'city lights' would turn on.
              Delta Auto Care
              Herndon, VA
              703.435.1375
              • straight6pwr
                • Sep 2004
                • 3450
                e30s are designed to keep the low beams on when the highs come on. they were never designed a different way.
                • evil_twin
                  • Nov 2007
                  • 2965
                  I don't understand why you're are arguing with me when you already told me this...
                  Originally posted by straight6pwr
                  its a relay thing. on cars equipped with sealed beams from the factory, the low beam is a dual filament bulb. therefore, when you flip on the high beam, the power is switched to the 2nd filament of the low beam, and is removed from the 1st filament which is what the new smileys are wired into. solution: theres a relay jump you can do to eliminate this. youll have to search for it, its one of the tricks to get independent fogs that also allows you to keep on highs/lows at the same time.
                  Delta Auto Care
                  Herndon, VA
                  703.435.1375
                    • 34834
                    my car has been wired with the #30 jumper for what, 6 years now? It's never been an issue. I don't see how you could screw that up to be honest.
                    • evil_twin
                      • Nov 2007
                      • 2965
                      WTF, who says anything about screwing anything up?
                      Delta Auto Care
                      Herndon, VA
                      703.435.1375
                        • 34834
                        you said it was ghetto, as if it was going to break and cause a fire or something. I'm just saying it works fine and will probably last longer than you have the car. And it's not like anyone can see it, so the argument for rewiring anything is pretty weak. At least the jumper is easily reverted back to stock, which makes it less of a hack job IMO..
                        • evil_twin
                          • Nov 2007
                          • 2965
                          Well, there is where our problem is. Ghetto is used loosely in this thread. My definition for ghetto is not up to par. Jumping the wire does do the job, but it's still not up to par in my book, hence why earlier I said 'to each his own' because something that is just good enough and works for you, isn't good enough to me. I'm pretty much done with this thread. Thank you for the help guys. And thanks for the mini arguments :-P
                          Delta Auto Care
                          Herndon, VA
                          703.435.1375
                            • 34834
                            but why? you don't have a good argument as to why it's not a "solid" modification. If it works forever, nobody can see that it's just a wire, and it never causes an issue, and it's easily reversable, what is wrong with it?
                            • evil_twin
                              • Nov 2007
                              • 2965
                              How about this... When/If the relay does go bad, that would mean I would have to desolder or replace both relays verse just replacing 1 relay.
                              Delta Auto Care
                              Herndon, VA
                              703.435.1375
                                • 34834
                                who said anything about soldering them together?
                                Soldered connections are actually bad in cars, because the vibrations will weaken and break the solder and the wires will come apart. Just put a dab of solder on the end of the wire (so the individual strands don't smush out), stick the ends in the right pins of the plug and put the relays on top. :)
