Turn Signal issue
  • sajone
    • Mar 2023
    • 1
    Turn Signal issue
    Hello everyone,
    I realise this is a relatively common issue however I cant seem to find a post with similar faults to mine on here. I have no lights on the dash or any bulbs going when i use the stalk or try hazard switch, but when i use my central locking (aftermarket alarm) the 4 corner amber lights still work.
    Currently i have gone through the following to try and diagnose:
    Fuses - fine
    Relay.- fine
    Next step was to try and remove the hazard switch to have a look at that. Can anybody else offer any other guidance?
  • Vincenze
    • Apr 2019
    • 1034
    What about the flasher relay?
    There are videos on YouTube.
    • Panici
      • Dec 2009
      • 2543
      Start with the hazard switch. Going from memory, but I believe all the turn signal wiring is fed through there.
      Next I would suspect the aftermarket alarm system. How did it tap into the original turn signal wiring?
      If there are vampire / quick / T-Taps on there, the factory wiring may be damaged.
      Wiring diagrams for your year can be found here:
