Help needed with Alpine CM5908 in a BMW E30
  • peterb
    • May 2021
    • 17
    Hi
    I have a BMW 325is with an Alpine CM5908. Original installation, came with the car. It developed a crackling sound so a couple of capacitors were changed in the amplifier output stage. The sound is good now but only with the engine off. With the engine on there is a loud buzz and a hum. Figured something was wrong with the ground but everything is connected correctly. All original, nothing has been changed in the wiring. There is no CD player connected. The only thing I noticed that the white paste between the large aluminum block at the back of the unit and the amp is almost gone. Not sure what it's for and if it's important. Any help with this would be appreciated
    Thanks
    Peter
  • noid
    • 1537
    If its interference sounding, but music still plays, check the hood to body ground.
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
    • peterb
      • May 2021
      • 17
      Thanks. I didn't know the hood was grounded to the body on these models. It's a 325is. The symptom, by the way, is the hum or whine increases with the RPM increase. There is no hum or whine with the engine off. The music is fine.
      • cory58
        • 1021
        Interesting. I don't think either of my E30s have that hood-to-body grounding strap.
        1992 325i Cabrio
        1988 320i Touring
        2000 M5
        1977 530i
        2015 328i - Euro Delivery/Performance Center Delivery
        BMWCCA
        E30CCA
        • bradnic
          • Jul 2012
          • 3554
          Swapping a couple of caps in the radio isn’t necessarily going to fix your noise problem completely.
          HOWTOs:
          DB vert plastic bumpers
          OEM Keys
          MTech1 docs
          88 ix Lach/Card
          91 ic Calypso 3.1
          86 Cosmo 2.7
          OEM+ or bust!
