E36 radio connector into E30 factory wiring
  • AmosCake
    • Feb 2021
    • 217
    Anyone have a diagram of e36 radio plug spliced into e30 wiring. I want to use a e36 cd43 radio. Note, my factory wiring was already butchered to install aftermarket radio by PO
  • TobyB
    • 5243
    nope, but here are 2 diagrams that ought to give you what you need to make the splice-
    t
    • AmosCake
      • Feb 2021
      • 217
      t
      Good looking out, thank you
      • AmosCake
        • Feb 2021
        • 217
        t
        Question, the e36 pin out has a 2 12 volt switch wires (Violet/white and black/white) and a battery wire (red/white) but the e30 only has two 12v Switch (violet/white and red/green). Do I splice the battery wire from the e36 plug into one of the 12v switch on the e30 harness effectively having a 12v and battery from the e36 going into one 12 v wire on the e30?
        • TobyB
          • 5243
          I'd think you'd need to find an 'always hot' wire somewhere in the E30 to send to the E36 radio to keep it alive when the power's off.
          t
          • bradnic
            • Jul 2012
            • 3552
            this is what you're looking for. did the diagram on the top for a customer, and helped them build an adapter (their pic below). You can get everything for about $40 plus the crimp hardware, tools.
            Note this is a common ground premium sound setup.
            HOWTOs:
            DB vert plastic bumpers
            OEM Keys
            MTech1 docs
            88 ix Lach/Card
            91 ic Calypso 3.1
            86 Cosmo 2.7
            OEM+ or bust!
            • AmosCake
              • Feb 2021
              • 217
              [url=https://flic.kr/p/2pk38Nh]
              This is exactly what I’m looking for!!! Thank you very much!!
