CM5908 Code Help
This is a sticky topic.
  • Howaboutdat
    • Mar 2026
    • 12
    CM5908 Code Help
    I recently bought a CM5908 head unit from someone parting out their 1991 318i. They sold it to me without the code, saying that they lost the owner's manual (for some reason, they don't have the code). I have not tried contacting a dealer for the code yet. I'm just wondering if anyone can help before I try the dealer.
    The number on the radio is F00673399D
  • 82eye
    • Jan 2009
    • 2099
    bmw will not supply the code on anything so old. you'd need the vin of the original car it came from anyway.
    you'd have to open it up and read the solder connections properly for the code or resolder the connections to a known code. there used to be some info on it at rts auto and a few tutorials floating around the internet but i'm sure the links are long gone now.
    you bought a brick for the most part.
    edit: link to solder to a known code - https://www.rtsauto.com/bmw-radio-cm...-code-jumpers/
    Mod edit: Link on archive.org if the first one breaks in the future
    It only takes 3 screws to remove the bottom panel of a BMW CM5908 Radio. There you will find the code jumpers; these jumpers, based on how they are soldered determine the radio code. Note where the jumpers are numbered TDC-0 through 5: Jump only TDC-5 to set code 25142: *Pictured is TDC-2 jumped, you
    • Howaboutdat
      • Mar 2026
      • 12
      I managed to get the radio open and found the code jumpers, but they are all seemingly bridged already, so I would need to desolder all of them except TDC-5?
      • 82eye
        • Jan 2009
        • 2099
        correct.
        either interpret and de-code what those solder jumpers relate to, or de-solder and re-solder to one you actually know. those are the choices.
        at one point there was a chart someone had published with the de-code but it vanished about 20 yrs ago, these cars are old now.
        edit: also the pc board is known to be brittle and hard to work on with the age now. you need a decent electronics solder iron and a careful hand.
        • Howaboutdat
          • Mar 2026
          • 12
          I have managed to obtain the code. While the board was open, I decided to take a picture of the connections and send it to the people at RapidRadioCodes.co.uk. They had a system set up for some of the hardcoded models where you send them a picture of the code jumpers and the radio's serial number. They eventually got back to me with a code that worked: 44442.
          I'd like to thank 82eye and the people at RapidRadioCodes for their help unlocking this radio.
          • 82eye
            • Jan 2009
            • 2099
            sweet, that's a good resource to know for the future.
            • 2mAn
              SeƱior Mod
              • 20992
              This is pretty amazing stuff... I'm going to pin this to help anyone in the future to allow use of the OEM radio
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              Make R3V Great Again -2020
              • 82eye
                • Jan 2009
                • 2099
                this means we also have 2 known codes if the resources go down.
                edit: if anyone else gets a known code we should publish it here.
