Tacho...
  • TDE30
    • 7042
    Tacho...
    My tachometer has been dead ever since the B25 swap (circa 1+ year ago) and I was wondering what exactly I need to do to get it to work. The car is an '87 325e with the motor out of an '89 325i if that makes any difference. There is a 325i coding plug in there right now and everything but the SI lights (probably dead battery, but not associated with my tacho problem) and the tachometer works. I read FredK's article on StrictlyEta and it didn't really cover my current situation.
    Hopefully it's not a faulty tacho, as I hear there is some sort of wiring change that must be made to get it to work, but I was wondering if anyone on hear knows what I need to do.
    TIA.
    - Trey
    E90 325i/6 (ZSP, ZPP, ZCW)
    E36 325i sedan
    E30 325i sedan
    Volvo 945T
    • 34839
    dead SI battery = no tach.
    • TDE30
      • 7042
      So if the SI battery is dead, only the tacho won't work?
      Because everything else works fine right now.
      - Trey
      E36 325i sedan
      E30 325i sedan
      Volvo 945T
      • deekay
        • 28
        im having the same problem i just baught a 87 325i with a 325e motor in it and the tach doesn't and the mpg doesn't work and the inspection light flickers sometimes and idk whats goin on.
