Radio Wiring
  • shay91
    • 82
    Radio Wiring
    I have a 89' 325i Convert.
    Can anybody tell me the wire configuration?
    Purple/White..... 12+ constant
    Brown/Black...... Ground
    White............... Power Antenna
    Red/Green......... ???? (Makes the chime come on)
    Blue................. ????
    Yellow.............. ????
    White............... + Front Speakers
    No black wires or nothing with a black stripe to tell me the negative for the speakers. I've touch the wires to something and the system played but I couldn't figure it back out. The old connectors have been cut.
    WTB: 88 325i Convertible Top
  • shay91
    • 82
    ttt
    • e30:)
      • 728
      blue is power antenna
      the two whites are for one of the speakers
      • shay91
        • 82
        my white is a power antenna. I put it to the constant and it rose up. I had it once before but when I took the radio out I forgot to label my wires :(
        • shay91
          • 82
          Can that guy StereoInstaller1 chime in here lol
          • yellowducman
            • Jul 2009
            • 34
            White is the color on the car for the antenna. Blue is the color out of an aftermarket head unit. I just did this yesterday but can't remember the other colors. I did a search on the forum though and found them pretty easy.
            • shay91
              • 82
              uh huh
              • StereoInstaller1
                GAS
                • 22679
                Purple/White..... 12+ constant: yellow (on deck)
                Brown/Black...... Ground: Black
                White............... Power Antenna : Blue or blue/white
                Red/Green......... ACC: red
                Blue................. Not used
                Yellow.............. Not used
                White............... Amp turn on
                Grey/red...illumination: Orange or orange/white
                So now you need to figure out if you wanna bypass the amp or not.
                Closing SOON!
                Thanks for 10 years of fun!
                • moatilliatta
                  • 6149
                  Is the factory amp worth bypassing? I got a Alpine CDA150 for a e34. Just curious which way i should go.
                  @Zakspeed_US
                  • thundering02
                    • Apr 2009
                    • 109
                    I wired the entire car fresh for my new stereo. 16ga wires for the speakers and for the power of which I only used what appeared purple to me as the 12 volt switched power... took the ground and power from the cig lighter. (course the left over bits of the harness was mangeled from a PO)
                    85 Toyota pickup.
                    85 325e sedan daily driver.
                    Various s13 bits for sale. Also a complete stroker kit to be listed soon.
                    DriftSTL.com driftpirates.com
                    • ThreeTwentyFissel
                      • Apr 2009
                      • 220
                      Their's too many whites mention, How do you figure out all of them?? How about some links for an accurate set up?
                      Simplicity is your best option!
