DDM HID kit
  • CR325IS
    • 514
    #31
    so the one by the lens i plug into my car and the male piece on the end of that one I plug into the ballast?
    • hoseklamp
      • 214
      #32
      Yup.
      I know on some systems, that line can be bypassed because the existing car plug is the counterpart to the plug on the ballast in order to decrease the excess amount of wires up there. But to avoid confusing you, the answer is yes.
      • rich4rdee
        • 595
        #33
        Originally posted by skatingzooyork
        I have the 55w 8000k (standard size ballast) in my lows and 55w 6000k fogs in my e34. I went w/ the 8000k because I heard the 55w washes out the color so I was trying to get the white/blue tint but I'm actually going to 6000k's in my lows because the 8000k's don't have enough light output and are "too blue" for me, but they aren't purple at all...
        Great product though!!
        i'm looking into getting a set of these too but i'm not sure which output to go with. i'm assuming 55w is gonna be brighter than 35w and i want a predominantly blue-ish hue but if you think they're not bright enough maybe i'll go down to a 55w 6000k.
        also, what bulb type do i want? h1 is set as the default...
        • skatingzooyork
          • 251
          #34
          I would definitely go with 55w 6000k ones. They still have a blueish tint and will be bright. As for which bulbs, you just want the stock type.
          http://www.jfalesphotography.com
          91 318is m50nv - New toy/project
          95 540i - Wife's DD
          • aworthybrother
            • May 2007
            • 899
            #35
            I am ready to order a set soon, what would be the "whitest" / OEM look HID from DDM?
            35W 6000k
            55W 4500k / 5000k
            55W 6000k
            Thanks.
            • bimmer_E30
              • 5001
              #36
              how about the depo smiley headlights for sale on ebay..what kind of hid do you plug into these?
              Originally posted by e30e
              • ak-
                • 12422
                #37
                35W 6000k
                55W 4500k / 5000k
                55W 6000k
                Thanks.
                55w 5000k
                Trust me, 35w will leave you wanting more. It just wan't bright enough.
                I have 55w 6000k and they have the SLIGHTEST waffleswaffleswaffleswaffles hair sized blue hue to them. So my friend, I reccomend you the 55w 5000k.
                I also had the 35w 6000k, but it seriously left me wanting more.
                To show you how much more, I only had it on my car for around 10min before I decided it wasn't enough.
                (sold it 2 days later to some kid with a teggy for $70 lol.)
                Good luck!
                1991 325iS turbo
                • aworthybrother
                  • May 2007
                  • 899
                  #38
                  Originally posted by ak-
                  55w 5000k
                  Good luck!
                  Thanks. Is 55W 5000k not too bright enough to be pulled over?
                  • Inline Sex
                    • Jul 2009
                    • 346
                    #39
                    Cops can't pull you over if they're blinded by your headlights. It all works out
                    Check my feedback HERE
                    • ak-
                      • 12422
                      #40
                      As long as you have projectors(which I'm sure you do) and make sure they aren't pointed higher then your high-beams(flick your high-beams with your lows on to check against a garage), then you're all good.
                      If your car is lowered, then even less to worry about.
                      You're welcome!
                      1991 325iS turbo
                      • CR325IS
                        • 514
                        #41
                        where did every1 mount their ballasts?
                        • ak-
                          • 12422
                          #42
                          My driver side is behind my coolant overflow tank with the wires tucked under the tank itself.
                          Passenger side is mounted/double-taped to the inside wall adjacent to the low beam light housings.
                          1991 325iS turbo
                          • MrSlacker
                            • 2494
                            #43
                            Just to clarify, if using US Ellipsoids, I should get:
                            DDM HID Kit Slim Ballast (35W or 55W)
                            55 Watt, Bulb Type H1, 6000K
                            Correct?
                            Whats the difference in Bulb Types?
                            My Seller/Buyer Feedback
                            Performance Aftermarket Parts & Accessories
                            • hoseklamp
                              • 214
                              #44
                              Correct?
                              The US Ellipsoids use a 9006 bulb for the lows.
                              The only difference in bulbs is the mounting and wire connections.
                              • dude8383
                                • Jan 2005
                                • 10387
                                #45
                                Correct?
                                The difference is that you're a friggin newb.
                                You need 9006 bulbs for the U.S. ellips, I would go for 55w and maybe a step down from 6k. I will find a thread for you with comparisons, you whore.
                                *EDIT*
                                Look here: http://r3vlimited.com/board/showthread.php?t=154653
