CD43 Head Unit & Audio Amp Fundamentals - A Primer [LONG]
  • StereoInstaller1
    GAS
    • 22679
    #31
    Pierre, the speaker level inputs sound far worse than the RCA inputs.
    Closing SOON!
    Thanks for 10 years of fun!
    • pegase747
      • Jul 2006
      • 279
      #32
      Originally posted by bmwman91
      Yup, that's how you would do it.
      BMWMAN91,
      a question for you ?:
      As you have well depicted the CD43 in this thread can you tell me how is the equalisation curb on the CD43 straight out of the unit ??
      I plan to ass the JL Audio cleansweep if the curb is not flat.
      If the curb is flat then I guess I can just use the Bass/Treb of the Unit itself right ?
      lets say if i use the CD43 speaker wires straight to my alpine 4-chan amp Hi-level inputs, and then to 2 good component fronts and 2 coax rear, with a Sub, will i have decent sound ?
      Would that be an improvement to add an external curb flattening processor ? Or the Cd43 will perform good enough ?
      Cheers Pierre
      1988 E30 ALPINA B3 2.7 #224/257 Made in Buchloe
      see more : http://www.r3vlimited.com/board/showthread.php?t=71686&referrerid=12460
      • pegase747
        • Jul 2006
        • 279
        #33
        Oups double post...
        • bmwman91
          • Oct 2004
          • 3134
          #34
          Originally posted by pegase747
          BMWMAN91,
          Cheers Pierre
          I have not done any tests with the onboard EQ. If you plan to run a system using passive crossovers, then yeah you can probably try to use the CD43 EQ. If the system is going to be multi-amped & use an active crossover, then just leave the CD43 flat since EQing that will affect all channels. Any decent active crossover will allow gain adjustment too.
          Transaction Feedback: LINK
