windows still have power after ignition switched off.
  • payney8
    • Jun 2007
    • 899
    Any ideas? My windows/ window switch lamps still have power after i have switched the ignition off. Does anyone have a wiring diagram or had similar problems?
  • Charley
    • 396
    I do have something similar going on with my car. I get power
    to the switch if one of my door is open enough so the dome
    lights are on...
    It only works if the dome lights are on if there not then I don't
    have power to the switchs.
    I think its kinda neat but don't think its supose to be that way...
    Charley
    • payney8
      • Jun 2007
      • 899
      yeah mines the same as well. Im thinking it has something to do with a relay as you can hear one switching when you play with the dome llights. I just need a wiring diagram to sort it out
      • blindwOw
        • 124
        Alright so I'm having the same issue(if its an issue at all). I'm just wondering, is it normal to always have power to the windows?
        I'm just trying to figure out what is draining my battery. I let it sit for 2 days and my battery is dead.
        '87 Zinno 325e
        • DaveSmed
          • Apr 2007
          • 1407
          Wow, that's a new one.
          Pull Fuse 19, see if the window switches are still lit with the door open.
          -Dave
          2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
          Need some help figuring out the ETM?
          • bmw325csi
            • May 2007
            • 4045
            i had this problem in the past too. remove the circuit breaker switch and check if the 2 wires are reversed.
            harry/harout
            • george graves
              • 20003
              What are you thinking? That's that switch is directional with respect to current flow? I'd have to look, but I'd doubt it.
              Originally posted by Matt-B
              • StereoInstaller1
                GAS
                • 22679
                I bet your unloader relays are stuck "on"
                Closing SOON!
                Thanks for 10 years of fun!
                • george graves
                  • 20003
                  alarm install gone wrong?
                  • StereoInstaller1
                    GAS
                    • 22679
                    That would take incredible stupidity...but I have seen a radio installed with the acc and dash lights connected together...
                    Closing SOON!
                    • evilnickwong
                      • Aug 2007
                      • 302
                      Mine also work if my front doors are open enough to trigger the dome lights (basically when the door switches are grounded). Doesn't work with the rears open though.
                      • blindwOw
                        • 124
                        How will I know if its reversed? And you are talking about the window circuit breaker switch for the windows right?I know that thing works because I was sitting in my car with the windows up wondering why they wouldn't go down when I first got the car.
                        I will try that tomorrow when there is light out.
                        I don't have an alarm system.
                        '87 Zinno 325e
                        • bmw325csi
                          • May 2007
                          • 4045
                          oh no, sorry, i messed up.
                          when my windows were always on it was because the cigarette lighter wire was connected to the window breaker.
                          harry/harout
                          • george graves
                            • 20003
                            right on - glad you fixed it.
                            • blindwOw
                              • 124
                              Since you say that, I'm guessing the cigarette lighter is always supplied power? Correct?
                              '87 Zinno 325e
