Luke worked on my stereo.
Wire joins: solder vs. butt connector
.Nothing wrong with crimps as long as you use the right sizes and have a decent crimping tool. Nothing wrong with soldering as long as you know how and properly insulate. I don't think it's much of an issue, they each have their applications."I'd probably take the E30 M3 in this case just because I love that little car, and how tanky that inline 6 is." - thecj
88 M3 - LACHSSILBER/SCHWARZE
Luke please give me a model number/picture of this magical crimper. I must give it a try.
I currently use the kind that just has the single peg that dimples the connector. It works great.
Just as a side note - I was looking around a while ago, and purchased this more expensive tool "heavy duty crimper", that's suppose to be the proper tool. Man does it suck:
Last edited by george graves; 07-14-2010, 12:26 AM.Originally posted by Matt-Bhey does anyone know anyone who gets upset and makes electronics?
I got the channel lock crimpers Luke is talking about after his recommendation and I have to back him up in that they are the best crimpers you can buy. At least, for insulated terminals that is. They kind of suck for non-insulated, but I bought a different pair of crimpers specifically for that.
I will also agree that Scotch Locks sucks ass. They never work as they should, form a crappy loose connection and just all around suck.
I personally will always crimp connections in cars for the reasons that Luke listed. There is a time and place where soldering is necessary, but I do not think it is in a place where moisture/vibration/etc. is prevalent.
I kind of like the idea of the crimp connectors that have a low temp solder and shrink wrap built into them. Basically you crimp them on as normal, then use a heat gun or micro torch to solder/heat shrink all in one. I imagine this would be the best of both worlds, but IMO, is overkill for most situations. Even crimp connectors with built-in heat shrink is overkill for inside a vehicle (great for exterior stuff though).
A question at this point: where does one find the heat+solder or just heat-shrink-wrap crimp deals? I'll look for the channel-lock pliers too.
http://www.channellock.com/Category.aspx?zcid=125 ?
That (^) be the crimpers that have spent SO many hours in my hands.
If ya wanna waterproof connection but don't have solder/shrink goodies hanging around, try squirting a tiny bit of normal RTV or whatever silicone in the end of the butt before you shove the wire in and crimp it.
I worked with a guy from Alaska. He taught me that and some other tricks, but I can't remember them or I stole them so completely I think I made them up myself.
Originally posted by nmlss2006 View PostA question at this point: where does one find the heat+solder or just heat-shrink-wrap crimp deals?
Originally posted by nmlss2006 View Postwhere does one find the heat+solder or just heat-shrink-wrap crimp deals?
Originally posted by NitroRustlerDriver View PostI got the channel lock crimpers Luke is talking about after his recommendation
Originally posted by StereoInstaller1 View PostButt connectors do not have those issues, as the crimp (and you cannot pull mine apart, I promise) actually forges the wire into a solid structure with the metal of the connector.Originally posted by Matt-Bhey does anyone know anyone who gets upset and makes electronics?
I'll take some pics of my soldered connections that were still there after my hu was ripped out of the car...passed probably a 100+ lb test lol.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
I speak with 8 years of experience working on wiring that sees the worst possible environment: huge vibration, intense salt spray, blasted by road debris, and more vibration. Class 8 trailer light wiring. Did I mention there is a ton of current? Think 10+ amps contiunous through a winter blizzard driving on frost heaves sprayed with salt and sand 24 hrs a day, 365 days a year. Solder doesn't last, non-insulated butts don't last (both covered with top quality shrink tube). The only connection that lasts, and the only ones that I have never had to open on my equipment is the Grote heatshrink insulated butts. They are expensive (over $0.75 each when buying them by the bucket), but god damn they are the best. They are double wall insulated with glue, and transparent so you can see the quality of the connection, and the glue expanding outwards creating an air-tight seal. The added bonus is that when diagnosing an electical problem, you can see if there is any corrosion inside, which is rarely the case. I've only had a handful out of thousands corrode, mostly due to error during installation (too hot, melted shrink tube, or not hot enough allowing the glue inside to fully flow to the ends). Repairs that I have done on factory wiring with these crimps have lasted over two million miles on our BC-bound trailers, and countless miles on our local haul trailers. Nasa doesn't have to worry about potholes while loaded with 50,000 lbs of freight and ice buildup on wiring swinging it around.
Originally posted by Axxe View PostI speak with 8 years of experience working on wiring that sees the worst possible environment: huge vibration, intense salt spray, blasted by road debris, and more vibration. Class 8 trailer light wiring. Did I mention there is a ton of current? Think 10+ amps contiunous through a winter blizzard driving on frost heaves sprayed with salt and sand 24 hrs a day, 365 days a year. Solder doesn't last, non-insulated butts don't last (both covered with top quality shrink tube). The only connection that lasts, and the only ones that I have never had to open on my equipment is the Grote heatshrink insulated butts. They are expensive (over $0.75 each when buying them by the bucket), but god damn they are the best. They are double wall insulated with glue, and transparent so you can see the quality of the connection, and the glue expanding outwards creating an air-tight seal. The added bonus is that when diagnosing an electical problem, you can see if there is any corrosion inside, which is rarely the case. I've only had a handful out of thousands corrode, mostly due to error during installation (too hot, melted shrink tube, or not hot enough allowing the glue inside to fully flow to the ends). Repairs that I have done on factory wiring with these crimps have lasted over two million miles on our BC-bound trailers, and countless miles on our local haul trailers. Nasa doesn't have to worry about potholes while loaded with 50,000 lbs of freight and ice buildup on wiring swinging it around.
