Do all e30's come with central locking?
  • caffeinatedsoap
    • 360
    As the subject states. The PO of my car installed a door off of another car and it doesn't lock/unlock with the drivers side lock. Also the truck won't lock or unlock either door. I feel as though it may not have central locking. I figured they all had it after my POS optionless 325e had it.
    1992 318ic
  • EndreM
    • Jul 2009
    • 513
    No.
    I've had four, all without central locking.
    '91 E30 316i
    '97 Rover Mini 1275
    • 801coppertop
      • 293
      Mine didn't work till I pulled off the frond door panel unplugged all the central locking wires. Than when I plugged them back in it worked. Also I replaced door lock cylinder. It was well worth $35 at pelican.
      • caffeinatedsoap
        • 360
        If I have a car with central locking and one without central locking how hard is it to move over those parts. I've never seen it mentioned before.
        1992 318ic
        • DaveSmed
          • Apr 2007
          • 1406
          You have it if you have a US market E30. (exc MAYBE in an early 318 )
          -Dave
          2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
          Need some help figuring out the ETM?
          • bernzpeed
            • 3917
            check the bottom of the lock cylinder in your trunk if it has an actuator. if you have one then you have central locking.
            89 E30 S52
            Transaction Feedback.
            • reelizmpro
              • 9464
              Since you're in the US, given the cars listed in your sig since you don't mention which....yes you have central locking. They put it in everything, even the 84 318i I believe.
              88 M3 - LACHSSILBER/SCHWARZE
              • glucklich21
                • 1912
                Off topic, but why would the rears not unlock with the other locks? i.e. manually unlock them.
                • gearheadE30
                  • Jun 2007
                  • 3734
                  Not true. I have a 318is that doesn't have them. It's a 3/90 build date, so it was literally one of the first US cars. To my knowledge, US production began in 3/90. It also appears to have come with a 2 button clock, although it was equipped with a sunroof, LSD, and premium audio. Go figure. I have seen one other 318is without central locking, also a march build car.
                  Project M42 Turbo
                  • reelizmpro
                    • 9464
                    Anybody else with a 90 318iS that can confirm this? It doesn't make sense that they would install sunroof, premium audio, etc but no central locking? that's pretty basic but I have limited experience with 90-91 318iS'.
                    These guys seem to think they came standard. Maybe yours just doesn't work?
                    • Jean
                      • 18228
                      Not all
                      • StereoInstaller1
                        GAS
                        • 22679
                        The central locking harness is built into the main harness, not separate at all. I just parted a central locking car, so I have a complete system that is 100% functional...but to unwrap the entire car harness and make an add on system would take me hours and hours...plus then you would still have to install the damn thing!
                        If you really REALLY want it, I can do it, but it ain't gonna be cheap. You would also have to add the wiring into the doors, which would require splicing the door jamb wiring as well...assuming you don't have the harness.
                        If you wanna find out if you have that harness, what you would want to do is take your drivers speaker out and look for a white plug, 2 rows, about 12 or 14 wires on it. IF you do that, take a pic (NOT a cell phone pic please, I need to see wire colors) and post it here.
                        But to answer your question, yes, it could be done.
                        Closing SOON!
                        Thanks for 10 years of fun!
                        • StereoInstaller1
                          GAS
                          • 22679
                          BTW: I would expect to find that harness UNDER the cover that fits below your left speaker, in the "well".
                          Closing SOON!
                          • soupiemelody
                            • 188
                            First post, just want to add that i have a 91 318i four door, build date 7/1990 and it does have central locking.
                            1991 318i Past
                            1990 325ic Past
                            1998 540i/6 Past
                            1988 325ic Present
                            1998 M3 Present
                            2000 M5 Present
                            • StereoInstaller1
                              GAS
                              • 22679
                              Yeah, the vast majority of US E30s do have central locking.
                              So now that you posted that, time to get some pics together and post them up, say hi and make a thread to introduce yourself.
                              Welcome to R3V!
                              Luke
                              Closing SOON!
