Got Bass? Spring box build is here! E34s too!
  • NeoMishMoo
    • Jul 2009
    • 448
    #241
    Here is my passenger bass hole, lines up great
    But the driver side is off by just about a half inch.
    I think I've still got the tar under there, thats why the fit is so snug under the speaker baskets, but that shouldn't have anything to do with my problem should it? As that would just make the box higher or lower.
    West German BMWs, they just don't make the same as they did before the wall fell.
    ^Case in point: Auto-Repair Technology. Everytime my car isn't starting or acting up I let it sit, sometimes for an hour, sometimes for days. But it eventually fixes itself.
    • StereoInstaller1
      GAS
      • 22679
      #242
      Stop whatever the hell you are doing.
      Go remove ALL the trunk tar, your box WILL NOT fit with it in, as I have said about 10 million times.
      That looks like you cut the carpet flaps out of the port holes...I hope you did not, that is what holds the port tubes in.
      With that extra 3/4" of trunk tar, the box is not in place.
      Closing SOON!
      Thanks for 10 years of fun!
      • NeoMishMoo
        • Jul 2009
        • 448
        #243
        So they shouldn't be symmetrical ok because I was measuring 13" from passenger bass port to edge of box and 12 5/8" from driver bass port to edge of box. That 3/8" would just about fix my problem.
        Here are my measurments. I did 2.5" and 2" distance for both holes as instructed in your install thread. Both holes should drilled using the same measurements right? Because on your install thread you just have a picture of one side measured out.
        The holes I drilled are 2.75 inches apart.
        • NeoMishMoo
          • Jul 2009
          • 448
          #244
          The box fit all the way against the wall just fine (well a little snug) with the tar intact. Sorry I didn't read anywhere to remove the trunk tar on either of your box install threads.
          What carpet flaps on the port holes are you referring to? Are you talking about on the carpet rear deck where the speakers go? I drilled the hole on the way through the metal and the carpet, as is pictured in your install thread. Or are you talking about the carpet inside the box's holes? I left that intact.
          The 3/4" inch tar will only make the box sit lower not more to one side or the other won't it? Regardless I'll go do that whilst I wait for a reply.
          EDIT: alright well didn't know anything about this damned trunk tar, so guess I'll be down there for a couple more hours, Chisel, spud bar, axe, its coming slowly but surely. Luckily its a little bit under 40, glad I didn't do it last week when it was 70. If I only had dry ice and an air chisel.
          • NeoMishMoo
            • Jul 2009
            • 448
            #245
            Removed all the trunk tar at the top of the trunk, The box does slide in more nicely, but the port hole is still off. I removed the side liner in hopes I could move the box to the side a bit but no luck. It is still hitting the battery wire.
            Here is a picture after removing the tar and reinstalling the box. The driver's side port is at that angle because that is what it takes to get it to actually start to go into the box. EDIT: That sharpie semicircle to the right of the driver's port is about where I figure I'll need to cut to get it to fit correctly.
            I've got to work tomorrow so I won't be able to put any more effort into it until tommorrow night or so. I'm probably going to have to just cut more off my rear deck so I can position the port correctly but it looks like in order to make the port fit it will be rubbing the brace, It actually looks like I might have to cut into the brace a little bit. But hopefully the port will just slide snugly next to the brace and into the box.
            Before I do more cutting I'd like to figure out what went wrong. My holes look just about identical to the ones you did in your install thread, so I'm just not sure whats wrong here. EDIT: Again my holes are 2.75" apart, could anyone confirm that is correct? Here is where I compared both mine and luke's holes (bottom of page) crap forgot the link: http://www.r3vlimited.com/board/show...=120407&page=2
            Last edited by NeoMishMoo; 03-27-2011, 07:00 PM. Reason: added some additional info
            • Oplopanax
              • Feb 2011
              • 10
              #246
              Finally got my stereo installed, including the Infinity sub in my sweet sweet box. However, I can't get the box up flush with the back of the seat/skipass. It looks like I am several inches short of making it. It's not an issue of being too tall, it's an issue of being too wide.
              Am I doing something wrong, or is there a trick I am missing? The car it's mounted in is a 1995 540i.
              Still, even NOT being flush with the ski pass, it still sounds great!
              • EN318isPDX
                • Oct 2007
                • 4373
                #247
                It requires some kicking to both of the back sides of the box.
                • Oplopanax
                  • Feb 2011
                  • 10
                  #248
                  Did that and then some. I actually tried to pound it in with a hammer (protected the box by using a piece of wood). No dice. It's not close enough in size to just push it through with force.
                  • EN318isPDX
                    • Oct 2007
                    • 4373
                    #249
                    Did you remove the tar stuff in the trunk?
                    • Oplopanax
                      • Feb 2011
                      • 10
                      #250
                      The 540 is a V8 rather than the I6 to which Luke had referred to earlier, i.e. no tar stuff in the trunk to remove.
                      • EN318isPDX
                        • Oct 2007
                        • 4373
                        #251
                        Oh my mistake, this is E34, I have not done an E34 install! Sorry Best of Luck to ya!
                        • Oplopanax
                          • Feb 2011
                          • 10
                          #252
                          LOL, no worries! I forget that this is an E30 forum :)
                          • EN318isPDX
                            • Oct 2007
                            • 4373
                            #253
                            If i wasn't such as skim reader i would have noticed you posted
                            • Jean
                              • 18228
                              #254
                              My e34 has no trunk tar loooool
                              • NeoMishMoo
                                • Jul 2009
                                • 448
                                #255
                                Got most the trunk tar removed, at least at the front of the trunk, It didn't come out very easily at all, especially the area over the exhaust pipe where it was nice and sticky. Box still not fitting though. Anyone else buy a 12" box? Anyone successfully installed it yet?
