Originally posted by Cletonius
View Post
The fusible link is actually for a smaller wire that runs along the main power feed. If it is broken, power will go everywhere except the engine electronics, as everything else is powered off of the large cable. A fusible link is a section of wire that is four wire gauges smaller than the wire it is protecting, and it has a special coating to prevent fire when it blows. That's it, it simply is there to be the first thing to go in the case of a dead short.
I have tons of stupid wiring ideas, some of them even work! ;)
Your mirrors are powered through K7 via Fuse 19. Check and see if you are getting power at the aux fan temp switch on the radiator, that is on the same fuse.
