Fog light Relay
  • Tismael711
    • 791
    Fog light Relay
    Does anyone know where one can purchase a Fog Light Relay for under $15? I believe its part # 61-31-1-380-013 or 61-31-1-374-631 and the relay color is black.
  • Cletonius
    • 2809
    I've been doing a bunch of electrical work lately and have compiled a list of all the relays I've come across on the various boards. Here's the list, perhaps it may help you find a less expensive relay. I've had good luck at my local BMW dealer getting relays for cheap. They'll usually knock the price down if you haggle a bit. Hope this helps.
    Disclaimer, these are the relays based upon the best information I have. It's possible your wiring is different than what I have found. Here's the relays for a late model sealed beam car:
    K1 Normal speed relay - 61 31 1 375 474, Orange plastic case
    K2 Horn relay - 61 31 1 375 474, Orange plastic case
    K3 High beam relay - 03 32 204 401, Bosch PN, metal case with violet stripe
    K4 Low beam relay - 61 31 1 373 912, Black plastic case, no tabs.
    K5 Unloader relay - 61 31 1 375 474, Orange plastic case
    K6 High speed fan relay - 61 31 1 375 474, Orange plastic case
    K7 Unloader relay - 61 31 1 375 474, Orange plastic case
    K8 Fog light relay - 61 31 1 375 474, Orange plastic case
    Most of the relays (474) are your basic make contact relays with a resistor across the coil. The 474 is not available any longer. The alternates may not still be available. Orange is recommended.
    61 31 1 378 238 - Orange plastic case, with tabs.
    61 31 1 373 156 - Green plastic, no tabs.
    61 31 1 378 301 - Yellow (gelb) plastic case, with tabs.
    03 32 019 456 (Bosch) - Orange plastic case, with tabs.
    0 332 014 454 (Bosch) - Light blue plastic, no tabs.
    The K3 (401) relay is a 5 pin changeover relay with a resistor. The original metal case is no longer available. The 911 part is recommended
    61 36 1 388 911 - Violet plastic case with mounting tabs.
    03 32 209 151 (Bosch) - Black plastic case.
    The K4 I'm not absolutely sure about. This is the one that has the most variance over the years. According to the diagram, it's a 5 pin relay with dual outputs where the output legs are not tied. The 912 fits the bill for that. If yours only takes a 4 pin relay, it's likely it's the 474 part from earlier. Here are some alternates.
    61 31 1 373 911 - Mint green plastic case, with tabs.
    61 36 8 353 447 - Mint green plastic case, with tabs.
    more:
    K1, K2, K4, K5, K6, K7 - 4 pin. Basic make-contact relay with current limiting resistor across the coil. Typical part numbers:
    61 31 1 375 474 - Orange plastic case, no tabs.
    03 32 014 454 (Bosch) - Light blue plastic, no tabs.
    K3 - 5 pin. Change-over relay with current limiting resistor. 87a is hot at rest, 87 is hot with the relay energized.
    03 32 204 401 (Bosch) - Metal case with violet stripe.
    K8 - 4 pin. Make-contact relay with current limiting resistor and a diode on the output leg of the coil.
    61 31 1 374 631 - Black plastic case, no tabs.
    61 31 1 380 013
    Main Relay - 5 pin. Make-contact relay with surge suppression diode across the coil and a diode on the input leg of the coil. Output provides dual 87 pins.
    12 63 1 711 266 - White plastic case, with tabs.
    61 36 1 729 004 - White plastic case, with tabs.
    12 63 1 729 004 - White plastic case, with tabs.
    Fuel Pump and O2 heater relays - 4 pin. Basic make-contact relay with current limiting resistor across the coil.
    - Josh
    1990 325is
    Need a shift boot?
    Looking to buy shift boot frames, PM if you have one to sell
    Here's what happens when you let the internet pick your license plate
    • DaveSmed
      • Apr 2007
      • 1407
      K8 absolutely must have that diode, or your car will do weird shit.
      -Dave
      2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
      Need some help figuring out the ETM?
      • redsubdivisions
        • Feb 2011
        • 1762
        Or you can just shell out the $15 and bite the bullet. It's not a terrible price, but it's not the best either. Are you trying to accomplish independent fog lights?
        1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
        2012 Passat TDI - DD Duty
        2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
        • Tismael711
          • 791
          no...not independent fogs....just the regular hook up. I switched to a plastic bumper with the integrated fogs and the lights went crazy. Headlights stayed on real low..when i hit the switch to turn them off...they didn't go off. I've solved my problem..I found an 0013 K8 relay in a car at the junk yard. Since then the lights have worked properly.
          • trackjunkie21
            • Jan 2010
            • 3962
            The wipers have the same kinda of relay.
            Originally posted by Wh33lhop
            VANOS: sometimes you just need to go full retard.
            • freeride53
              • 11972
              +1, and cliffs:
              don't bother getting one from a yard, it'll only cause you more stress.
              1983 Peugeot 505 STI
              1992 Volvo 240 Wagon
              • DaveSmed
                • Apr 2007
                • 1407
                +1, and cliffs:
                "Huh?" on both counts.
                The wiper module is the size of three relays and has twice the amount of terminals, not to mention it works completely different.
                And I get tons of that stuff from yards. $3 for 5 complete E30s worth of relays. Why not!
                -Dave
